Old 09-20-2010, 08:46 PM   #1
sfcharr
Newby 69 C10 stepside
Need some advice. I recently purchased a sweet 69 stepside with a 283 SBC from a 67 chevelle. I'm having drivability issues with either the Holley carb or the HEI vacuum advance. I set the idle and adjusted the fuel mixture on the carb. It doesn't seen like I'm getting any vacuum for the distributor from the carb. any ideas?
sfcharr is offline   Reply With Quote
Old 09-20-2010, 10:51 PM   #2
68anniversary
Re: Newby 69 C10 stepside
Have you tested the vacuum port with a gauge? If you are getting vacuum at the carb then maybe the advance diaphragm is bad? Make sure you have the line connected to the right port on the carb.
68anniversary is offline   Reply With Quote
Old 09-20-2010, 11:00 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
also maybe the power valve in the holley?
what's the advance at idle with it unplugged and then with it hooked up and revved up?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-20-2010, 11:02 PM   #4
Dads69C10
Dads69C10's Avatar
Welcome. Once you figure out the problem be sure to post some pics of your truck
1969 C10 stepside
1973 Cheyenne Blazer
Dads69C10 is offline   Reply With Quote
Old 09-21-2010, 08:19 AM   #5
68Stepbed
68Stepbed's Avatar
Keep in mind that carbs have ported and nonported(full vacuum) vacuum ports. The ported vacuum is what is used for vacuum advance distributors. There won't be any vacuum at idle. The port you should be hooked to is on the side of the metering block a little over halfway up on the passenger side.
Does the truck run ok, or is there a problem?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-23-2010, 09:25 PM   #6
sfcharr
Jeez, thanks for all the responses! Yea the vacuum is hooked up to the port on the metering block. I messed around with the idle mixture screws a little the other day and it improved the driveability a lot. I need to get the vacuum gage and maybe a vacuum pump to check the advance. The truck seems to fall over itself at part throttle. It idles fine, and sounds real healthy when you hammer it. But that's not the way to drive this old truck.
Old 09-24-2010, 08:54 AM   #7
68Stepbed
68Stepbed's Avatar
Does it have a very rich idle? If so, check the power valve. It sounds like you have a lean condition. Yes, get a vacuum guage. Most Holleys come with a 6.5 power valve. That works fine on a cammed up engine with low vacuum signals, but not so good with stock engines. Find out what your highest vacuum reading is, divide by half and get the power valve closest to that number. For example: 20" of vacuum divided by 2 = 10. That means you would need a 10.5 power valve.
The power valve opens during vacuum signal loss. The higher the PV number the sooner it will open and enrich the transition circuits.
Also, buy some literature for Holleys. They are invaluable when tuning a carb.
Matt
Old 10-04-2010, 06:59 PM   #8
sfcharr
Ok, what i discovered is that # 3 plug is not firing. Wire checks out fine, plug checks out fine. It has a HEI distributor. any ideas how to trouble shoot this distributor. I have a multi-meter.
Old 10-05-2010, 09:06 AM   #9
68Stepbed
68Stepbed's Avatar
Could just be a bad terminal in the cap. Also, a wire can somtimes show to be good, but it may have a weak section in insulation and grounding out. I would try a new cap first though.
Matt
Old 10-05-2010, 11:26 AM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's a great holley site---http://www.67-72chevytrucks.com/vboard/showthread.php?t=230964
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-05-2010, 08:56 PM   #11
sfcharr
Turns out the contacts in the cap were burned up. I believe this was interrupting the spark. I will know for sure Saturday when I replace cap and rotor.
Old 10-06-2010, 06:37 AM   #12
jim zag
ENGINE BUILDER
jim zag's Avatar
Turn the idke mixture screws in until they bottom out and then turn out 1 1/2 turns. This is a rich starting point. I usually end up at 1 1/4 turns out. Adjustment less than one turn out usually results in off idle lean condition. Make sure the accelerator pump cam arm adjustment has no slop at idle.
JIM ZAG
jim zag is offline   Reply With Quote
