is it worth it?
i have a 402 in my truck.. rebuilt probably 5-7 years ago.. it runs fine now.. but i have had to replace gaskets here and there.. so my question is.. would it be worth it if i pulled it. check the cylinder wear if its still good and pistons are still good give them a good parts wash bath. install bearings and new cam and lifters and gaskets and everything? my idea.. im sure its got carbon build up and get one of the summits rebuild kits for like 400 bucks and hopefully give it a few miles per gallon this way? or shall i just leave it and wait til a major problem occurs.. take about half tank to drive 60 miles
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#2 | |
![]() ![]() Join Date: Dec 1999
Re: is it worth it?
If it runs fine why mess with it?
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
Re: is it worth it?
just seein if by cleaning the stuff would get me better mpg.. i want a different cam tho. i want a bigger one to give me the more loping sound
Big Red - Now its a SWB!
Re: is it worth it?
doing some tuning would probably give you more of a boost in MPG than doing a rebuild. What carb are you running and how is it jetted? What ignition are you running? These both can be tuned to optimize mileage.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Re: is it worth it?
Also forgot to ask what tranny and rear are you running? OD and/or taller gears could help out too.
Re: is it worth it?
The $400 you spend would take a long time to make up in whatever fuel economy you did find. Not to mention that it will cost you WAY more than $400. We all konw what happens when you pull an engine to do a quick "refresher". One thing leads to another and pretty soon you are spending $2,000 trying to save $500 in gas.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#7 | ||
"I ain't nobody, dork."
Re: is it worth it?
If you want a "lopey" cam... you can forget good MPG...
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
