Old 09-20-2010, 09:41 PM   #1
pumpgas
pumpgas's Avatar
Rear wheel cylinder problems
Ok heres the scoop.....I have the narrower rear end of the 67-72 trucks and am trying to replace the rear brakes, basically everything from the backing plate the the drum, so I got all the parts finally today and the wheel cylinders don't fit the one's off the truck are narrower than the replacements and the parts store only shows what they sold me for all rear coil spring trucks. So my biggest problem is what can I do or where can I go from here? Any and all help would be greatly appreciated.
00' Z28 ("wifes" car)
92' Mustang w/sbc everything needs a little heart beat
87' GMC Sierra Classic Short Bed Fleet side almost stock
69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it
pumpgas is offline   Reply With Quote
Old 09-20-2010, 09:43 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Rear wheel cylinder problems
I replaced mine when I reworked the brakes last year, and didn't have any issues.
Which parts store? I went to O'Reilly and they fit direction in the location.
Gotta ask... are they on the right side? IIRC the fittings went one way and one way only.
I'll see if I can come up with a part number for you.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-20-2010, 09:45 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Here's a list from O'Reilly:
http://www.oreillyauto.com/site/c/se...kup&vi=1310233
-Nate
Old 09-20-2010, 09:52 PM   #4
pumpgas
pumpgas's Avatar
http://shop.advanceautoparts.com/web...p2HomeClicked=
These are what advanced says is the only one's for coil spring 1/2 tons.
They didn't make a 12 bolt 3/4 ton did they? Other wise I see no option for any other rear wheel cylinders no matter what year the rear end is.
Old 09-20-2010, 09:58 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Is the "nozzle" angled or straight?
They might have given you front cylinders (angled) instead of rears (straight).
-Nate
Old 09-20-2010, 10:16 PM   #6
pumpgas
pumpgas's Avatar
There straights......there just a little wider than what we took off.
Old 09-20-2010, 10:22 PM   #7
sjarrett71
sjarrett71's Avatar
Are the bodies of the wheel cylinders wider or are the tits wider when they are mounted in the wheel cylinder. If the tits are wider you can squeez them in quite a bit but do it before you hook up the brake lines. They might be a little haard to squeez together but they will go.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 09-20-2010, 10:22 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Huh... well unless they gave you the wrong ones, I would consider checking with another parts store and see how they match up.
Was the truck stock? Could the rearend have been changed at some point in its life?
-Nate
Old 09-20-2010, 11:01 PM   #9
Mike J
vw guy & now c-10 guy
Mike J's Avatar
i just did a complete rebuild of my rear brakes and my new wheel cylinders didnt wanna fit into the backing plate either, they came from o'reilly. i just did a slight grind on them until they fit- seems like i had to use different mounting bolts as well
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 09-21-2010, 06:27 AM   #10
pumpgas
pumpgas's Avatar
The actual body of the wheel cylinder is wider on the new one's. There are 2 ears on the backing plate that the cylinder sits on and the old one fits great the new ones rubber ends are being push in by those ears. Possible may have to grind the ears down/off tonight we'll see what happens.
Old 09-21-2010, 07:12 AM   #11
cdowns
cdowns's Avatar
i'd clean the old ones up and take them into a good autoparts store like NAPA to have them get me the proper ones
Old 09-21-2010, 07:57 AM   #12
my67chevytruck
Under Construction
my67chevytruck's Avatar
we just did this on my son's '67 without issue as well. you do have to squeeze the new ones pretty good to get them to seat between the tabs so they will mount correctly though. let us know the outcome.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-21-2010, 08:45 AM   #13
truckdude239
truckdude239's Avatar
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-21-2010, 11:32 AM   #14
95light
95light's Avatar
Same issue, I just used the bench grinder and took off a little til they fit. No problems after that.
95light is offline   Reply With Quote
Old 09-21-2010, 03:19 PM   #15
Wrenchbender Ret
I used to run imto this often when I did a lot of brake work. I just cut the safety brackets on the backing plate back a little.
Wrenchbender Ret is offline   Reply With Quote
Old 09-21-2010, 05:13 PM   #16
1-PU70
1-PU70's Avatar
They do make different bore sizes. Sometimes if you take the dust shield off the cups inside have the bore size molded on them. I would compare the bore sizes of the two. Good luck.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 09-21-2010, 08:19 PM   #17
pumpgas
pumpgas's Avatar
Everyone I've looked at for these monsters says they only offer 1 and the new one's are about 1/2" wider than what came off the rear so I guess we will be trimming those safety hooks down a tad.
