Old 09-20-2010, 09:48 PM   #1
Brad54
Brad54's Avatar
Nova subframe for '60-'62?
I know about the cross member conversion from the later trucks, but I just found a Nova subframe in a junkyard, so I'm wondering if there are any advantages to using it over the conversion crossmember.
I'm thinking it would get the truck down lower in the front, and a lot more stuff is available for the Nova/Camaro subframes than trucks.
Thoughts?
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 09-21-2010, 12:24 AM   #2
Captainfab
60-66 Nut
Re: Nova subframe for '60-'62?
I personally wouldn't put a Nova subframe under these trucks. It would be a lot of unnecessary work IMO. There is actually a lot of aftermarket support for the pickup suspensions anymore.
Old 09-21-2010, 01:46 AM   #3
ConnDemned
I have a 60 with a Camaro clip. The clip doesn't go out far enough to mount the rad, rad support and bumper. Plus it is a lot wider at the front so you would have to fab front supports for said items. Also the steering box is on the opossite side of the frame rail so you have to either use some steering u joints and "bend" it around or figure out how to mount a trucks steering box. If I didn't buy it this way I would go with the cross member swap, plus I'm not all that good at welding fabbing. I don't have pics other than my cell phone and I am not sure if those will even post. The swap has been done I know another guy on here did it and has the front end complete, so it falls mostly on your choice of money, fab skills, and time to do either one. Good luck with it.
ConnDemned is offline   Reply With Quote
Old 09-21-2010, 03:57 AM   #4
Brad54
Brad54's Avatar
Thanks guys.
I'm sticking with the later truck front crossmember/coil spring conversion.
-Brad
Old 09-21-2010, 09:42 AM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Good idear ...
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-21-2010, 04:46 PM   #6
CVA59
Originally Posted by Brad54 View Post
Thanks guys.
-Brad
Very wise decision Grasshoppa!
I used an 86 donor truck for my front and rear conversion. Worked perfect.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
