Old 09-20-2010, 11:51 PM   #1
68350
68350's Avatar
th400 shift question
My gmc has a th400 in it behind the 427. The previous owner stated the tranny had been built for towing. the fluid and filter are getting changed this week. My question is the tranny will stay in first until 65 mph or roughly 6000 rpms. That isn't even close to normal compared to other th400 trucks I've drove. Seems like it is sticking in first. Is there anything else I can do to make it shift lower?
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 09-21-2010, 05:14 AM   #2
JimKshortstep4x4
Re: th400 shift question
The vacuum modulator and /or vacuum to the modulator would be the first thing to check out.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-21-2010, 07:15 AM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
also check the down shift switch...not sure where your is but mine is on the side of the carp...theres a plug on the DS near the speedo cable try pulling it off and running it...if that fixs it then its the switch
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-22-2010, 04:31 AM   #4
raycow
Is this with a "normal" throttle opening when starting off, or are you talking about the pedal being floored? If floored, does it upshift when you let up on the pedal?
Ray
raycow is offline   Reply With Quote
Old 09-22-2010, 09:47 AM   #5
68350
68350's Avatar
raycow, yes this is under full throttle. then when you let up it shifts. if you floor again though(under 55 mph) it downshifts right back into first.
Old 09-22-2010, 01:25 PM   #6
raycow
Well then, I don't know if you could call it a malfunction. I am thinking the transmission may have been deliberately modified for racing. It could certainly be returned to stock configuration by any competent shop. If you want to try it yourself, I would recommend looking at the governor first.
Ray
