Junior Member
![]() Join Date: Mar 2007
Are trailing arms the same left & right?
except for the parking brake cable bracket. Are they straight? can I switch them side to side?
I have 2 good drivers sides & 2 rusted passenger sides....
frontstreetcycle on Instagram |
Re: Are trailing arms the same left & right?
no they r different
Junior Member
lay a right and left side by side ... you'll see the difference
Junior Member
I did, Thats why im asking. I cant "see" any difference other than the park brake cable bracket...
#6 | |
Its a Truck Thing......
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
Junior Member
thats easily fixed...
i thought the ends where the bushing go were at different angles
1972 gmc c25 292/sm465 dana 60 w/5.13s 1973 vw super beetle 1600cc/4spd(baja bug) 1974 chevy c60 351v6/np-540+2 speed eaton rear 2005 chevy cobalt 2.2l |
#9 | |
Junior Member
ill check that carefully. Thank you
also to me, it looks like if u take the right side to left or vice versa the angle of the u bolts would go the wrong way. btw this is a 1972 frame and susp.
1972 gmc c25 292/sm465 dana 60 w/5.13s 1973 vw super beetle 1600cc/4spd(baja bug) 1974 chevy c60 351v6/np-540+2 speed eaton rear 2005 chevy cobalt 2.2l Last edited by 292farmer; 09-21-2010 at 08:20 PM. |
Junior Member
laying on the shop floor side by side everything looks straight. i will unbolt one from my truck & swap the "wrong" side arm on & see what happens...
Just like to part out trucks!!
I thnk they are the same except the E brake bracket
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
#13 |
Junior Member
I think so too & if I dont fall asleep under my truck I will know soon.
![]() Gonna swap one now...
#14 |
if you really cant see the difference between a left and right trailing arm you need to get your eyes examined by a good doctor
#15 |
^^^ we haven't seen his its possible he has some aftermarket ones, i saw some while looking for the pics i posted that are just about perfectly straight(pst i think).
#16 |
If I remember right I sold a drivers side to a guy and he needed a pass side, he just cut off the e brake bracket and was driving the truck the next day. They do not have a sideways bend in them, they only bend upwards, I've taken quite a few off and shipped quite a few
#17 |
I just spent the day under my '65 putting on dual exhaust and based on what I am seeing they are the same, except for the emergency brake bracket which is not a big deal to change.
This would make a lot of sense from GM's perspective, (1) less part to make and keep in stock! Last edited by lakeroadster; 09-21-2010 at 10:22 PM. |
#18 |
I have both of them laying on my shop floor. I looked real good tonight and I cant see a difference other than the E Brake brackets.
#19 | |
Junior Member
I did the same & they look the same except for that bracket. Im too tired tonight but I will get one swapped soon. Thanks
#20 | |
Or maybe those that think they're 'bent' differently L to R need to?? From what I remember, they're straight w/the only difference being the e-brake tabs.
#21 |
![]() Join Date: Apr 2005
+1
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#22 |
![]() Join Date: Jun 2009
look straight to me
#23 |
#24 |
i'd say straight i did crawl beneath my truck and noticed mine has a more of a tapered end where u bolt goes in depending or which angle u look at it it looked bent, till u actually sight down edge.
#25 |
Junior Member
Thanks to most of you. Guess Ill hold off on the eye doc visit...
