Old 09-21-2010, 04:11 AM   #1
ET702
engine mount question??
this is my first project and am having trouble with the install of my engine mount brackets. the truck just got a mustang 2 front suspension. will anybody send me pic of there engine mount brackets if you have installed the kit please. I am about to make mine and wanted some suggestions on how and what you used to make them. Ive also just moved to las vegas and i am looking for a good garage or mechanic. . will the stock mounting brackets work.??
Thanks pics coming soon.
ET702 is offline   Reply With Quote
Old 09-21-2010, 07:35 AM   #2
gkesseru
gkesseru's Avatar
Re: engine mount question??
I just went through this yesterday. I swapped in a complete 81 front end into a 68 and found out that the standard V8 towers were too tall and too wide to fit this combination. I decided that the best way to fix this was to make a V8 simulator and then use it to reshape the towers.
For the towers, I had to heat the bottoms cherry red and hammer the dimple out of the bottom to lower the bottom part and then I cut off 1/2 inch off the top end.
It was really helpful to be able to use the V8 simulator bracket to check the fit as I went.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 09-22-2010, 01:12 AM   #3
Travis K
Travis K's Avatar
I used almost the exact same setup while fabbing the mounts for my 5.3L. Worked way better than installing and removing the actual engine 50 times to verify measurements and fitment.
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=407865
Travis K is offline   Reply With Quote
