Speed QUESTION
Hello Guys
looking to purchase an after market speedometeor for my truck, I'm wanting something that will be accurate. Tire size is P275 50/15 all the way around. The rear end gears are 273 stock. The motor is a 383 stroker. I'm really wanting something that will be accurate. Any help and suggestions are welcome. Thanks and if any of you have pictures or other websites that would help I would appreciate that also. Thanks, Jeff Main |
resident wrencher
Re: Speed QUESTION
the stock ones are accurate enough its all about the speedo gear in the tranny it has to be the correct one for you tire size and rear gears and properly fit the tranny and no chips or worn teeth or itll bounce around a lot or if you have a newer truck a claibratble vss will do with a elcetric speedo
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Speed QUESTION
GPS speedo, you dont have to calibrate nothin, just hook up power, ground, antenna and lights, you off!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
