Old 09-21-2010, 01:28 PM   #1
petefinsquish
1970 C20 engine & tranny swap info.
My friend gave me a driveline from a 87 suburban. 350tbi 700r4 driveshaft and rearend if needed. Since the truck doesn't have ac or doesn't need the smog equipment, is this going to be a difficult install with all the extra wiring for the smog or what are all your thaughts on it.
Thank,
Pete
petefinsquish is offline   Reply With Quote
Old 09-21-2010, 05:02 PM   #2
capev86
Re: 1970 C20 engine & tranny swap info.
fuel injected engines are designed to work as a package but you "may: be able to simplify some items. either way you more precise induction that will adjust to altitude changes, and an overdrive trans. you can't beat it!
capev86 is offline   Reply With Quote
