misc. questions
hello... i am new to the site, i have looked alot but finally set up an accouint. i have a few questions actually...
1 does the front disc brake set-up off a 71- 72 swap right over to a 70? 2 how do you get to the screws to take the dash pad off? 3 where is the best/inexpensive place to get after market parts? 4 i have eard of people just cutting a coil off to lower their trucks, good idea or bad idea? |
#2 | |
Re: misc. questions
I'm new as well and I can only really speak to two of those points. 1. No idea. 2. I can see mine in the bottom, the top doesn't have screws it has little push in plugs. 3. Everywhere. I've been poking around at random parts, I've found better prices on one part at LMC then a better price on another part at brothers, summit, jegs, classicparts, etc. Honestly there's 'some' consistency but not much. Just favorite all the aftermarket spots and get all of their catelogs then when you need something check em all and buy it where you find it cheapest, shipping counts! 4. Don't cut your springs. it's very hard to do accurately and even if you do you're still risking mechanical failure. Not to mention it's irreversable, if you buy some lowering springs you can put em on and if you ever want to go back you go back to the stock springs. you screw up your stock springs and you're just out a set of springs. |
Junior Member
![]() Join Date: Mar 2007
Re: misc. questions
#1 yes.
#2 lots of screws on the bottom front edge. #3 where ever you can get the best deal on the parts you need. Local auto parts srore is a good place to start... #4 no problem cutting springs. cutoff wheel on a 4" grinder works nicely. cut a coil & if its not low enough cut another half....
frontstreetcycle on Instagram |
yes, i do
Re: misc. questions
the disc brake setup should just swap over. just take the entire spindle and hardware. one thing you are going to have to have is the brake booster and proportioning valve to have the required pressure to the brakes
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
Re: misc. questions
Greenbox here is a good thread on dashpad removal. There are nuts on the backside also. http://67-72chevytrucks.com/vboard/s...d.php?t=390840
CHEVY/GMC VIN DECODERS |
![]() Join Date: Jun 2005
Re: misc. questions
1. Yes that setup will swap over but there are differences in the ball joints and tie rod ends. I believe there is a FAQ in this.
2. There are studs in the pad that go thru the top of the dash and you have to take the nuts off from the bottom, either 5/16 or 3/8 socket, I don't remember which. 3. As stated above. 4. IMHO, not a good idea. Better to buy lowering springs as stated. Also, WELCOME TO THE BOARD!!!!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Re: misc. questions
#1 From what Ive read researching for my own truck, no. There are some that require switching ball joints and tie rod ends and some that dont
#2 The dash pad has screws across the front and tabs that bend over slots in the top of the dash. I remember doing this to my 72 15 years ago. Im pretty sure I took the glove box out and loosened the gauge panel to get behind it to bend the tabs. #3 Depends on what your are after. If for instance you buy drop spindles that except 71-78 rotors, you can save money buy going to a local parts store rather than a mail order restoration type place for the rotors and calipers. #4 People have been cutting springs for decades. But on the other hand lowering springs are only around $100. |
Re: misc. questions
thanks everyone for all the info and pointers...
#9 | |
Cruzin
Re: misc. questions
4. useing a cutoff wheel is a good way just keep the heat down heat is the problem, 1 coil is usually around 2'' i think, we have even cut the rears and it was fine
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
