09-21-2010, 02:27 PM | #1 |
Where did you put your compressor
I'm building a 63 on bags, front and rear but I'm not sure on where to mount my compressor. Anyone has any pictures on where you mounted yours?
I have my tank bolts into the driver side frame so out of sight. |
09-21-2010, 02:46 PM | #2 |
Registered Loser
Re: Where did you put your compressor
Your compressor should go near the tank so the leader hose reaches. You may want to also put a water trap between the the compressor's leader hose and the tank.
What size compressor are you using?
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
09-21-2010, 02:55 PM | #3 |
Not sure as I am at work, when i get home I will look to see the size of the compressor.
What do you mean by a water trap? |
09-21-2010, 03:20 PM | #4 |
way2lo2
here is 2 pumps
09-21-2010, 06:44 PM | #5 |
09-21-2010, 07:42 PM | #6 |
Who Me?
This was my location of my compressor on my 65.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
09-22-2010, 07:34 AM | #7 |
way2lo2
Its a c- notch made from heavy wall 8" tube cut in half.
09-22-2010, 11:43 AM | #8 |
Registered Loser
A water trap/separator is a like a filter that keeps moisture from the compressor from getting into the tank, causing it to corrode from the inside. You could also put a drain in tank if you have an unused port on the bottom of it.
09-22-2010, 11:47 AM | #9 |
Registered Loser
I would put some gromets in those holes where your air and powerlines go through that steel.
09-22-2010, 11:51 AM | #10 |
Is it smarter to do two tanks and 2 compressors? I have 1 tank 5 gallons and 1 compressor. The Front takes most of the air because of the weight and the rear is fine because of no weight at all.
Any thoughts? |
09-22-2010, 12:06 PM | #11 |
Registered Loser
That really all depends. If your only going to drop it when you park and lift it to drive it then 1 compressor and tank will be fine. If you are gonna play with the switches alot then you will want to go with 2 compressors and tanks (or 1 bigger tank). It also depends on the size of the compressors. The bigger the compressor, the faster it will fill the tank.
09-22-2010, 12:36 PM | #12 |
True, I cant drop the front while driving as front almost sits on the control arms.
The rear is fine playing with while driving or parking. I will mostly use it when I park as it was set up for running 20s but I have gone in a different direction. I'm going to run 15" rims, red with white walls i think. |
