Old 09-21-2010, 03:55 PM   #1
swamp rat
swamp rat's Avatar
Cross brace missing?
I have a question, i have looked at a number of builds here and all that i have seen there was a cross member both foward and behind a rear frame tank install, i just went out and took some pics, i have 1 rear frame cross member (brace) about 12" from the rear of the frame and nothing else until about 2' from the front of the bed, am i missing a cross member?
The 3 pic's go from the rear of the frame looking at the passenger side
Disregard the squair tubing as that is part of my current hitch and will be removed for a reciver type later.
Thanks.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-21-2010, 04:37 PM   #2
Davetopay
Re: Cross brace missing?
No cross member at the forward leaf spring mounts?
Davetopay is offline   Reply With Quote
Old 09-21-2010, 06:23 PM   #3
swamp rat
swamp rat's Avatar
I'll have to look again but there is 2 holes on each frame rail at the spring pearch if i recall correctly, or is it possible some trucks didn't have one?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-22-2010, 04:27 PM   #4
swamp rat
swamp rat's Avatar
Yes i have the crossmember at the front spring perch and the other about 12" back from the rear of the frame. I did find another 3/4T build here with the bed off and it looked the same so i don't think i'm gonna be too concerned about it. Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-22-2010, 06:14 PM   #5
Davetopay
Yeah, my half k is the same way.
I have see several pics of 80's frames with no middle crossmember...which I find odd.
Old 09-30-2010, 11:21 AM   #6
mkp
In fact I am also having the same problem. I have the feeling that I am missing one cross member in my vehicle. I asked a lot of mechanics. Some of them said that I am missing one cross member while others said that some trucks come like that. I personally feel that some trucks are built with one cross member missing. I have decided not to bother about it anymore because till now I have not had any problem because of the missing cross member.
Truck Accident
mkp is offline   Reply With Quote
Old 09-30-2010, 12:06 PM   #7
swamp rat
swamp rat's Avatar
Yea my truck has been the same way every since its been in my family, since 76-77 anyway. I beel better knowing that i have since posted looked at a 4X4 build thd there frame was the same as mine.. Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
