Old 09-21-2010, 05:23 PM   #1
srea76
srea76's Avatar
Heather box on ac truck
Anyone have pictures or info on how to remove the heater box on an ac truck inside and out? I removed about 10 screws and nuts today and the thing still sticks to my firewall like superglue. No idea what I am missing to pull it loose.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
Old 09-21-2010, 09:06 PM   #2
jay6891
Car Knocker
jay6891's Avatar
Re: Heather box on ac truck
It does have a tar like sealant between the firewall and the housing. Not budging at all?
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 09-21-2010, 09:19 PM   #3
srea76
srea76's Avatar
I see the sealant when i removed some of the screws. Very little budge. I hate to really put force on it and break something. trying to get it off to clean up the firewall before paint.
1984 Silverado
Old 09-21-2010, 09:49 PM   #4
rsavage
rsavage's Avatar
It has been a long time, but I think that there a couple of screws that go from the inside the cab out to the enclosure, not just those you can see outside. Did you get the bottom outside screws that you can't see at the bottom outside? Easier to remove and install with the inner fender removed and the right side hood hinge removed.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 09-21-2010, 10:01 PM   #5
srea76
srea76's Avatar
Yes I removed the ones on bottom. I have the front clip removed so it is not a problem getting to it. I also removed some screws on the inside. I think 2 or 3 there.
1984 Silverado
Old 09-22-2010, 06:01 PM   #6
jay6891
Car Knocker
jay6891's Avatar
Hmm... Did you disconnect the cable that runs to the hot/cold door? I cant remember what part the door is in. Inside or outside. But anyways you lay in passenger floor and you will see it running into firewall right above passenger feet. Little plastic grommet on it. Pull that and inside you will see a 3/8" or 5/16" headed sheet melat screw holding bracket for cable. Un hook that and if you are sure you got ALL the bolts out. Run a putty knife between outer manifold and firewall and cut/gently pry from the truck. Good luck
Old 09-22-2010, 06:12 PM   #7
srea76
srea76's Avatar
Thanks. I did pull the cables off the ac unit itself, but not off of the boxes. I will try that in a few days and get me a putty knife. Thanks again everyone.
1984 Silverado
Old 09-22-2010, 08:23 PM   #8
13lazer
13lazers' blazers
13lazer's Avatar
If I remember correctly you can reach the cable from the engine compartment near the passenger side wiper. You have to pull the top of the box back and look down and you can see the cable that you need to remove.
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
