Old 09-21-2010, 05:48 PM   #1
brad4176455
1968 Chevy C-10 rear end
I was wondering if anyone knows of a way to figure out what gears are in the rear end of my truck. I have a 1968 Chevy C-10 longbed with a 307 and a two speed power glide. I am looking a putting a new transmission in it but i would like to know what gears i have first.
brad4176455 is offline   Reply With Quote
Old 09-21-2010, 06:45 PM   #2
GASWAGON
AMERICAN IRON ADDICT
Re: 1968 Chevy C-10 rear end
Welcome! Pull the cover and look for some stamped numbers on the ring gear. A example would be 41 and 10 which would translate to 4.10 ratio. Divide the smaller into the larger to find your ratio. J.
GASWAGON is offline   Reply With Quote
Old 09-21-2010, 06:49 PM   #3
brad4176455
ok. thanks i will have to do that. Does anyone know what the stock rear end gearing is? Everything else on the truck is factory so i would assume that they didnt do anything to the rear end.
Old 09-21-2010, 06:52 PM   #4
GASWAGON
I think you will find 3.73 is your ratio. I believe that was the standard ratio for half ton in 67. A 4.10 ratio was a option. I am sure somone will correct me if I'm wrong.
Old 09-21-2010, 08:02 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
my truck was 307 3OTT with 373 open rearend
and he^^^^ told ya how to do it right
John
1999 Toyota Tacoma 4x4
Old 09-22-2010, 03:50 AM   #6
raycow
As already stated, 3.73 was the most common gear. However, you can find out what is actually in there without pulling the cover.
Jack one rear wheel off the ground, put the transmission in neutral, and the parking brake off. Put matching marks on the pinion yoke and differential housing. Turn the wheel exactly TWO revolutions and count how many times the driveshaft turns, estimating any fractional turn as closely as possible. That number is your axle ratio.
If the wheel is difficult or impossible to turn, you may have posi. In that case, jack both rear wheels off the ground and turn either of them only ONE revolution. Count the driveshaft turns the same way as for an open rear.
Ray
raycow is offline   Reply With Quote
