Quit if it's not FUN!!!
Steering Column - rebuild or replace?
Hey gang,
I finally got all the suspension done on my '70 stepper. On to the next task - sloppy as $#ll steering column and general wiring missteps. The steering column (auto-non tilt) is really sloppy. The shifter works, but it is really sloppy, like it has no detents? The wiring is just generally patched-up. I scored a usable main wirng harness from another member here. I've cleaned it up and got it ready to install. The rest, I can repair as needed. I've done a few searches here and have a sorta' plan. Looks like - remove the cluster and the column, then tackle changing-out the harness. Should I repair, or replace the column. Not a show truck, but I need a dependable driver. Oh yea, none of the turn signal cancelling works, so that would have to be replaced also. Need some advise - open to thoughts! Thanks to all, Toby |
![]() Join Date: Sep 2010
Re: Steering Column - rebuild or replace?
I reccomend an Ididit in basic finish and configuration. You will be done with the steering column issues if you do.
Replace it a tilt column, I recommend Kev's Classic's
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
Gone to greener pastures
![]() Join Date: May 2007
Beat me to it, Rene!
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
