Old 09-21-2010, 08:19 PM   #1
Leon E Morris
tilt steering thread ?
does anyone know if there is a thread on here showing how to change the intermediate shaft in tilt columns ? (van column for use in 67 pickup) thanks
Leon E Morris is offline   Reply With Quote
Old 09-21-2010, 10:24 PM   #2
cheyenne shortstep
cheyenne shortstep's Avatar
Re: tilt steering thread ?
There are two plastic/nylon? pins that keep the shaft from sliding that you will need to drive out to change the shaft. There are two ways to go about this, you can drill them or melt them either way you might need to give a couple taps with a rubber mallet to get the shaft to slide. It's really very easy.
cheyenne shortstep is offline   Reply With Quote
