09-21-2010, 10:23 PM | #1 |
Swaybars....
So I'm tryin to figure out which to go with on my 68 LongBed, not bagged in the usual sense. Only got bags inside the coils.
Thinking either Hotchkis or should I do NASCAR style splined? I realize the hotchkis is pretty much a bolt on vs. more fab work. Whatcha all think?
http://www.cardomain.com/id/Schralper |
09-22-2010, 03:30 PM | #2 |
Re: Swaybars....
I doubt you'll notice any benefit of the splined bars. But go big. Hotchkis or sway-away, even helwig is a good choice.
09-24-2010, 02:30 PM | #3 |
Re: Swaybars....
Bigga Betta...
I'll send you pics of my setup.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
09-24-2010, 02:40 PM | #4 |
Re: Swaybars....
Who sells the best one?
Posted via Mobile Device |
09-24-2010, 04:48 PM | #5 |
Re: Swaybars....
We offer a 1.25" OD bar with end links. Its not a fancy splined set-up but does the job well. It runs $250 and comes with all hardware and is powdercoated black.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
09-24-2010, 05:10 PM | #6 |
Registered Cruiser
Re: Swaybars....
Nate, do you make a larger OD bar or is that the bigger of the 2 your offer? I know it's somewhere here, but couldn't find it... Not really sure if they even need to be much larger than that?!
09-24-2010, 05:24 PM | #7 |
Re: Swaybars....
The other bar we offer is 1.125" OD... it runs $225.
09-24-2010, 05:38 PM | #8 |
Junior Member
Re: Swaybars....
Are you running tube arms or OE lower arms?
09-24-2010, 05:59 PM | #9 |
Re: Swaybars....
09-25-2010, 11:30 PM | #10 |
Re: Swaybars....
currently OE but was thinking might need to reinforce the bottom side w/ flat stock.
09-28-2010, 04:15 PM | #11 |
Re: Swaybars....
Your truck is RAD dude.....
