Master Procrastinator
Cab dimensions
I'm out of town working and found a cab 5hrs from where I'm working, trying to find out the length and width of a 68 cab, trying to see if it will fit in the box of my F250 so I could skip the 4hr drive home and save sometime and money, help would be much appreciated, thanks
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
Re: Cab dimensions
Not sure if it helps but. I've seen folks use carpet strips and two to three 2X4's across the bed and haul a fleet bed upside down on top of their bed with two straps. I'd think something similar with two 4X4's could be done with a cab.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Re: Cab dimensions
I have seen someone put one in a new body style chevy shortbed. Not sure how much different the bed sizes are though.
But the question is how are you planning to get it in and out with your 8 inch lift and 38 in tires? |
Re: Cab dimensions
Long 5'
Wide 6' 6" height 4' 8" |
Re: Cab dimensions
thanks, will do some measuring, as for the lift, would be tricky but I have 2 90ton over head cranes at work to set it on my trailer with if it worx out when I get back home, may need the trailer anyway, with my boxliner and everything it may not work
Re: Cab dimensions
I believe that it will fit if you turn it sideways as shown in the picture if the Ford bed is the same width as our trucks.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 09-23-2010 at 05:29 AM. Reason: Spelling |
Re: Cab dimensions
thanks, i'm gonna try this out
