425hp409
![]() Join Date: Oct 2008
6 lug axle shaft
I need two 6 lug axle shafts for a 1972 12 bolt rear diff that I am installing in a 1950 Chevy pickup
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
![]() Join Date: Apr 2007
Re: 6 lug axle shaft
I have a nice set from a 69 12 bolt. I bumped them to the top for you. Sharpie
i also have a set-sharpie is first. mine are from a '67
Under Construction
6 lug in a '72 axle?.... are'nt the axle lengths different for 67-70, and 71-72
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Junior Member
It must be 4wd.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
What lenght do you need? I have 2 axles you can have if they work for you!
425hp409
TONYPAUL
my axles are 31 7/16 inch long.
How are you measuring? From the outside flange or inside? Mine are 30 7/8" from the inside flange...
