![]() Join Date: Dec 2008
350 engine with A/C
This is a complete 350 engine with A/C including all brakets and pulleys Air cleaner to oil pan minus the power steering pump (the pump on my 87 GMC was shot so I pulled the pump off this engine). Engine# 3970010, Heads# 458642, Intake# 346250. It's a points system that looks like it was replaced and in good shape. The orginal owner was unsure if this engine was original because it was handed down to him through the family, dad, brother, then PO. After pulling engine and running numbers I've realized this is a much later engine probably out of a 79. If this was an original 350 matching the truck I would've used it. Unfortately it's not so my dad, brother and myself collectively decided that it is in my best interest to just drop a crate motor into my frame off resto truck. I did a compression test before I pulled it to make sure it was still in good running order and it is: Cyl 1-152psi, cyl 2-152psi, cyl 3-142psi, cyl 4-138psi, cyl 5-142psi, cyl 6-145psi, cyl 7-134psi, cyl 8-149psi.
When I first got the truck it had sat a while but I put new plugs in it, changed the oil/filter and ran some carb. cleaner through it and it ran very good. When I pulled the valve covers to get the model numbers for the heads I noticed that someone used sealant as valve cover gaskets and also the heads should definitely be removed and hot tanked to get all the grit and grime off. If I were going to use this engine I would have it hot steamed to degrease it and buy a complete gasket set for it, have a valve job done on the heads and put it all back together and run it. I am located off I-84 in Brookfield, CT 06804. I have a lift to load right into your vehicle. Anyone coming through CT on there way to the Carlisle meet this weekend feel free to stop and inspect yourself. I am looking to get $575 (lowered price) for everything. Anything you do not see pictured is currently stored including all the a/c stuff and brackets. Pics of the A/C stuff coming shortly. Last edited by Patsfan34; 09-29-2010 at 09:56 AM. |
Re: 350 engine with A/C
a/c stuff
Bracket and 2 rib pulley for power steering pump and a/c compressor
Questions?
![]() Join Date: Sep 2009
Neil, with everything you are including, that is a good price.
Always appreciate you Paul and Jason
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
To the top
Need all this stuff gone. New price $575!
Offers? Does someone want me to split it up? A/C system and just engine?
$400 for everything! Moving soon and don't want to bring this stuff with me.
come get it
#13 |
Good running 350 with a/c here. Carb is now sold. I will break it up if you don't need the a/c stuff.
#14 |
Moving this weekend and need this stuff gone. I'm open to offers.
#15 |
#16 |
Sold
| Bookmarks |
