Old 09-22-2010, 11:41 AM   #1
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
I'm About To Mount The Cab
I'm headed over to "the shop" this morning to find out what I actually have, but I have some help coming, so I thought I'd ask a question before I have all the data:
I THINK I have a 71 C10 frame and cab (and rad core support) mounts for the '71 frame. But I'm using a '68 cab. If I get over there, with all the help that's coming ($$$$), do I check the cab for numbers, check the donor 71 cab for numbers (C10? C20?) and then try to figure out whether I'm putting the wrong mounts on only AFTER the front clip and bed does not possibly line up (the front clip's off, the bed's on, but tilted with only one bolt holding it. Both are from the '71 C10).
Sorry for asking a "what if" question without the good info, but I couldn't make it over there last night. I have the P.O.-purchased cab mounts...brand new stuff...and the manpower coming this morning in an hour....
I want to put the cab on so I can start with the cab's body work...you know ...put a steering column in so I can move it around. Glass is out, almost fully gutted the cab, but the guy coming today is a body guy.... and I need a passenger rocker panel (I have the replacement) eyeballed by him, too. The cab on would be a big help. But not if I have to take it off again to change out the mounts by myself....
Thanks.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 09-22-2010, 11:48 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: I'm About To Mount The Cab
IIRC the cab mounts are the same for all 2wd 67-72 trucks. the core support mounts are diff for the 67-68, and the 69-72...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-22-2010, 12:06 PM   #3
Sammy
Don't forget a tape measure and leave the mounts loose till you get the front clip installed to fine adjust your gaps if need be. Hope your front frame rails are not FUBARED they can make your task a nightmare. Good Luck.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-22-2010, 05:30 PM   #4
magwakeenercew2jh
Decided to leave it all loose and ship the cab, bed and front clip to the body/paint man in three big chunks.
Right now, I'm waiting to settle on price.
When we do, I'll put the motor and tranny in the frame. We'll take the rolling chassis down to the body man for fitment.
Then back home for the fun stuff. I've got to grow some money somewhere.....
In the meantime, I'll clean up the motor and trans and keep inventorying the extra parts. Stripping that '71 cab down to the "bone" sure gave me a ton of screws...not to mention a bed full of stuff.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
