Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 09-22-2010, 12:31 PM   #1
MTCK
MTCK's Avatar
TBI off a 1990 Suburban
Complete stock TBI system off a 1991 suburban. Includes the harness up to the fuse block and to the ECM on the passenger side. It was only cut at the termination to the headlights, tail lights and starter. All connections intact for the VSS, TC lockup, knock sensor, TPS, MAP, coolant temp, distributor and injectors. Weatherpack connector installed just outside the TB for the injectors so that it could be removed without ruining the seal going into the TB. Parts / pieces included:
Throttle body
ECM
Harness
Distributor
Coil
MAP sensor
Knock Sensor
VSS
Coolant Temp Sensor
Complete instrument cluster including the electronic spedo and full gauges
I am sure that I'm forgetting something....
$475 Shipped to your door. US only.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-27-2010, 04:33 PM   #2
MTCK
MTCK's Avatar
Re: TBI off a 1990 Suburban
Also includes oil pressure sending unit. That's what I was forgetting... TTT
-Marcus
Project Plow Truck
Old 10-06-2010, 01:56 PM   #3
MTCK
MTCK's Avatar
Need this gone. $300 shipped.
-Marcus
Project Plow Truck
Old 01-09-2011, 11:11 AM   #4
kSStamp0182
LSX addict
kSStamp0182's Avatar
do you still have these parts? if so would you consider selling the gauges separately?
kSStamp0182 is offline   Reply With Quote
Old 01-09-2011, 11:13 AM   #5
kSStamp0182
LSX addict
instrument cluster i mean.
Old 01-09-2011, 12:51 PM   #6
MTCK
MTCK's Avatar
Sold it, sorry.
-Marcus
Project Plow Truck
