Old 09-22-2010, 04:09 PM   #1
JC_32
350 TBI Engine Miss
I am having an issue with my 1987 Chevy R-10 with a 5.7 TBI and a 700R4 Transmission.
Symptoms: Noticing a light and hard miss at idol while in gear.
details: This only happens while in gear and if the motor is warm
If motor is warm and I take it out of gear there is no miss.
No miss while driving at any speed.
Still getting 17-18 MPG
Recent Work: Complete tune-up.
Changed plugs, cap, rotor, wires and timing.
timed to 2 degress BTDC with the plug disconnected.
disconnected ground then reconnected so computer would set advance curves.
New O2 sensor and Cat.
Clarifications: When I gapped the plugs, the mfg recommended .35 but my book said .45
I gapped at .35 (should I go to .45?)
The truck does burn some oil.
I look forward to hearing some input.
thanks,
JC_32 is offline   Reply With Quote
Old 09-22-2010, 04:20 PM   #2
irishman999
irishman999's Avatar
Re: 350 TBI Engine Miss
It sounds like a plug wire is not making contact.
irishman999 is offline   Reply With Quote
Old 09-22-2010, 04:31 PM   #3
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
X2
did it start to miss after the tune up?
i would try see if the plug wires can be push farther down over the plug some times the wire can be at the end of the rubber boot so its just bearly making contact if that dosent work i would try another set of plug wires to see if it changes anything my diffrent make
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 09-22-2010, 04:45 PM   #4
JC_32
After the tune-up it ran great!!
a few tanks of gas I was getting almost 19mpg which is pretty good.
It's been progressively getting worse.
I haven't had time to look at it yet, but thought I would throw the post up to see if there were some suggestions other than what is on my mind.
my thought is the plug gap mixed with the oil burning. I'm thinking it's causing a plug to "clog" up due to the size gap?
thanks for the replies.
Old 09-22-2010, 04:57 PM   #5
irishman999
if you are sure the plug wires are making good contact pull your plugs and gap them the extra .10, clean them off with a wire brush too. where did you buy the plug wires and tune up parts?
Old 09-22-2010, 04:59 PM   #6
spudz
spudz's Avatar
Sounds like a cracked plug or cheap parts store wires.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 09-22-2010, 05:01 PM   #7
JC_32
The plugs are AC Delco and the tune-up parts picked up at O'Reilly's.
(putting up my shield to protect against the lashing..lol)
Old 09-22-2010, 05:02 PM   #8
JC_32
deleted...duplicate post???
Old 09-22-2010, 05:06 PM   #9
JC_32
Spudz, what wires do you recommend?
Old 09-22-2010, 05:06 PM   #10
irishman999
No big deal and no lashing, i did the same dumb move. The distributor cap i got from orielys melted the button that the rotor made contact with. Take all that bs back to orileys and try to get your money back, then go to Autozone and buy the premium components.
Old 09-22-2010, 05:30 PM   #11
spudz
spudz's Avatar
ac delco, taylor, moroso, msd, ect.. Nothing from a parts store.
Old 09-22-2010, 08:21 PM   #12
JC_32
All tune up parts are BWD with AC Delco plugs.
Old 09-22-2010, 08:36 PM   #13
nbpro
taylor all the way
nbpro is offline   Reply With Quote
