Old 09-22-2010, 04:30 PM   #1
jwa76fleetside
jwa76fleetside's Avatar
lmc trim
anyone have a 76ish pic with the LMC trim? did it fit right? someone put my trim on with sheetmetal screws and pop rivets....
76 Chevy Fleetside
63 Lincoln Continental w/ Ford Racing 460 (550hp)
2012 VW GTI
2013 Escalade
2008 Harley
jwa76fleetside is offline   Reply With Quote
Old 09-22-2010, 09:27 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: lmc trim
I don't have any pics, but I did order a piece just to see what it looked like. I can tell you that it will not match your factory trim. If you want OEM trim there arent many options unless you chase down NOS sets. If your not too picky, it would be better than what you have.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-22-2010, 10:00 PM   #3
menace121978
menace121978's Avatar
Re: lmc trim
i'm looking for an entire nos set now! from what i've heard i don't think the lmc stuff is going to work for me. ..
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-22-2010, 11:59 PM   #4
sixshooter798
Desert Rat
sixshooter798's Avatar
Re: lmc trim
I've searched far and wide for OEM style door trim. I found some for my 77 Cheyenne, do you have a pic of what you're looking for?
sixshooter798 is offline   Reply With Quote
Old 09-23-2010, 12:23 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: lmc trim
I suggest you order a piece and see for yourself. It isn't exactly like OEM in sheen and texture, but at least it all would match. I have a lot of NOS pieces and some of it doesn't match the others.
Articles-
"Refining Sierra"
Old 09-23-2010, 10:10 AM   #6
jwa76fleetside
Re: lmc trim
yeah i was planning on pulling all my OEM off since its got screws through it and then replacing it all with the LMC stuff so it all matches...
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 09-23-2010, 12:22 PM   #7
78 Chevyrado
Re: lmc trim
I put the aftermarket trim on my truck.... the only piece that didnt work was the lower rear bedside pieces. I had to reuse my old pieces there. Also you will almost HAVE TO reuse as many of the OE clips off your old trim as you can. The new clips with the new trim either dont match each other or are just plain wrong. The stick on parts are fine, everything else it pot luck. I think they fit about as well as the stock stuff I had before and they look fine as long as you don't mix them with OE stuff. the back lower piece I had to reuse doesn't stick out though, maybe its because it's on the bottom at a good angle or something. Mainly they just look older than the new stuff but you have to look really close. I wouldn't have tried to mix and match the upper pieces though.
The trims ok, the clips are terrible! to me it would be worth it to go to a junkyard and rob the clips off of some junkyard crap trim.
78 Chevyrado is offline   Reply With Quote
Old 09-23-2010, 12:55 PM   #8
jwa76fleetside
Re: lmc trim
Kenny,
it that a pic in your photobucket link??? the gray truck....
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 09-23-2010, 03:20 PM   #9
78 Chevyrado
Re: lmc trim
My truck stuff is in the 78 c20 album.
heres the link.
http://s160.photobucket.com/albums/t...2880/78%20C20/
Old 09-23-2010, 03:59 PM   #10
jwa76fleetside
Re: lmc trim
trim looks good from the pics....
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 09-23-2010, 04:15 PM   #11
78 Chevyrado
Re: lmc trim
they arent exactly like the OE trim, some were longer or shorter than the OE stuff, but then again the oe stuff wasn't perfect either. Actually some of the aftermarket stuff fit better than the OE stuff as they were a bit "too long". I'm happy with them overall.
Old 09-23-2010, 04:30 PM   #12
LS1_C10
Dont want a large Farva
LS1_C10's Avatar
Re: lmc trim
PO converted my 74 to the 80's style trim. Ive actually been looking very hard at the entire LMC trim set. Ill keep an eye on this thread for a while before I invest.
My 74 K1500(broken and sold)
LS1_C10 is offline   Reply With Quote
Old 09-23-2010, 04:50 PM   #13
78 Chevyrado
Re: lmc trim
I forgot I had this.
Reply 187 on this page has my review of the aftermarket trim from when I put it on my truck.
http://forum.73-87chevytrucks.com/sm...topic=9090.180
tip - reply 148
http://forum.73-87chevytrucks.com/sm...topic=9090.135
there is probably more trim stuff spread out in that thread, I don't remember exactly.
Old 09-23-2010, 04:54 PM   #14
78 Chevyrado
Re: lmc trim
A lot of different stores sell trim kits... they are the same brand stuff. so buy the cheapest one you can find. I bought a kit from one store, it was missing some pieces (they arent actual kits but pieced together by the store) and bought the missing stuff from two other stores because i didnt want to wait and they all were the same brand and matched up perfectly.
