Old 09-22-2010, 04:41 PM   #1
Yellow76
Yellow76's Avatar
456 gears with 35s?
Will i be able to drive the speed limit on the highway with 456 gears on 35 inch tires? Right now i have 37s with 456s but im not sure how fast im going cause my speedo is so off haha o and i have a th350 in it
Yellow76 is offline   Reply With Quote
Old 09-22-2010, 06:32 PM   #2
raycow
Re: 456 gears with 35s?
How fast do you want to turn your engine? 70 mph would be about 3065 rpm + maybe another 100-200 rpm for converter slip (with a stock converter - a loose one would be more).
Ray
raycow is offline   Reply With Quote
Old 09-22-2010, 11:23 PM   #3
Yellow76
Yellow76's Avatar
ya about 70 it has a 1500 stall converter in it is 3200 rpms to high to rev a small block for 20 min down the freeway?
Old 09-22-2010, 11:33 PM   #4
raycow
I don't think it will hurt the engine any - but you might find it uncomfortable.
Ray
Old 09-23-2010, 02:18 AM   #5
scottsdaleowner75
I wish i had gone with 4.56's instead of 4.10's with the 35's i'm running. But i am running a 700r4 as well.
scottsdaleowner75 is offline   Reply With Quote
Old 09-23-2010, 09:45 AM   #6
Psycho71
Psycho71's Avatar
When i do the gear swap in mine, it will be getting 4:56's to go with my 36" tires. Mine's not on the road yet, but I know i ain't gonna be linking the 36's with 3:73 gears.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 09-24-2010, 08:38 PM   #7
70 beast
Certified Hobbiest
70 beast's Avatar
heres a great gear ratio/ speed calculator.
http://www.grimmjeeper.com/gears.html
i ran 35s on my 70 with 4.56's and now i have 38's on my k5 with 4.56 and i would have to say my k5 does way better rpm wise than my 70 did. one difference between the 2 was the 70 had a th350 and the k5 has a sm465 but the final drive ratios are the same 1:1.
i looked up the difference and your rpm's would be a little higher with 35's as apposed to the 37's you have now.
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 09-24-2010, 10:55 PM   #8
Schralper
Schralper's Avatar
if i drove hwy ALL the time 456's would suck,
but 20 mi/min no big deal i do it in my burban all the time.
with my 35's/4.56 & OD, i'd do it w/ 488's if i were to do it again.
Schralper is offline   Reply With Quote
Old 09-28-2010, 12:36 AM   #9
Yellow76
Yellow76's Avatar
do you guy no what kind of tranny gear i would need to run with this set up?
Old 09-29-2010, 02:09 AM   #10
mkp
Chevy trucks are popular throughout the world for their performance. I had one of them when I was working in Dubai in the 1990s. It was pretty old, a 1977 Chevrolet C/K Cheyenne. I brought it from an Arab businessman in 1990. I was working as an engineer at that time and had to go to distant places as part of my job. This Chevy was my constant companion and it never gave me any sort of trouble. When I returned to US I sold it to an Indian driver who is still using it.
Truck Accident
mkp is offline   Reply With Quote
