Old 09-22-2010, 08:04 PM   #1
1985LT1_C10
1985LT1_C10's Avatar
turn on headlights and gas gauge goes to zero
just did a motor swap and now when i turn my headlights on my gas gauge goes to zero and my dashlights are non-existant and my buzzer goes off.....anyone have a clue as to what i did or didnt do????
Ross K
1985 Silverado LT1
1970 Chevelle SS396
1985LT1_C10 is offline   Reply With Quote
Old 09-22-2010, 08:14 PM   #2
GMC Guy
GMC Guy's Avatar
Re: turn on headlights and gas gauge goes to zero
is it just your gas gauge that stops working?
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 09-22-2010, 08:22 PM   #3
nbpro
Sounds like a loose wire somewhere. Ground or something. Either that, or you're getting bad bad BAD gas mileage. Lol (Christine, relatives maybe?)
nbpro is offline   Reply With Quote
Old 09-22-2010, 08:28 PM   #4
Buick455
I would second the ground issue as you have a high resistance somewhere. You can still have good voltage but as son as you have current that voltage will drop quick with a high resistance connection such as a bad ground from the chassis to the cab.
Buick455 is offline   Reply With Quote
Old 09-22-2010, 08:29 PM   #5
dmwphoto
dmwphoto's Avatar
Bingo, this is clearly the issue.
dmwphoto is offline   Reply With Quote
Old 09-22-2010, 09:45 PM   #6
1985LT1_C10
yes its only the gas gauge.....ill go over the grounds as that seems to make sense thanks guys!
Ross K
1985 Silverado LT1
1970 Chevelle SS396
Old 09-22-2010, 09:54 PM   #7
nbpro
Originally Posted by 1985LT1_C10 View Post
did a motor swap and now when i turn my headlights on my gas gauge goes to zero and my dashlights are non-existant and my buzzer goes off.....anyone have a clue as to what i did or didnt do???? !
humm what happen to dashlights are non-existant and buzzer goes off
Old 09-22-2010, 10:39 PM   #8
1985LT1_C10
im looking at schematics right now....it seems that i must have something crossed as well .....i installed a new headunit and i hooked everything up prpoerly so i think....guess ill pull that out and take another look
Ross K
1985 Silverado LT1
1970 Chevelle SS396
Old 09-22-2010, 11:38 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
check the power hookup.....just bought a 78 jimmy and it did the same kinda thing (it ajusts with dimming)this am looked under the dash and a cheap tac looks wired up wrong the power is from the light dimmer,but there is lots of loose wires yet to play with
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
