09-23-2010, 12:09 AM | #1 |
Front Control Arm U bolt
I am in the Garland TX area and in desperate need a Control Arm U Bolt ASAP. My girlfriends sons truck is setting in the school parking lot
1998 Pontiac Grad Prix GTP 1969 C10 396 TH400 3.08 posi |
09-23-2010, 12:45 AM | #2 |
Re: Front Control Arm U bolt
What year truck (disc or drums)?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-23-2010 at 01:01 AM. |
09-23-2010, 01:09 AM | #3 |
69 converted to 72 disc brake
09-23-2010, 01:26 AM | #4 |
I have drum & disc u-bolts. You need one now?
09-23-2010, 01:57 AM | #5 |
Rangers game is over & I haven't seen a response so I pulled a disc brake u-bolt & it's sitting on my toolbox. I could meet you @ the school in the am I guess (none of the Garland HS's are that far from me)??
I'll check back in early morning.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-23-2010 at 01:59 AM. |
09-23-2010, 06:51 AM | #6 |
autoparts sstore has common parts like this
09-23-2010, 10:43 AM | #7 |
I cant find the front one at a parts store I found the rear but not the front.
STOCI I sent you a PM
09-23-2010, 11:41 AM | #8 |
Thanks all I found them at NAPA
09-23-2010, 11:52 AM | #9 |
Around here, some do, some don't. I spoke w/him & suggested a local NAPA & he found what was needed.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-23-2010 at 11:53 AM. |
09-23-2010, 12:25 PM | #10 |
Wide n'Low
I know it's after the fact, but I got new one's from Napa as well, they are heavy duty for sure.
Part number is Napa 650-4065 comes in a two pack. Hope it helps someone, sometime..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
09-23-2010, 12:45 PM | #11 |
SCOTI, way to step up
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
09-23-2010, 01:18 PM | #12 |
Has more rust than truck...
Thanks for the p/n Twisted! And rep points for SCOTI (if we had them that is)
09-23-2010, 01:54 PM | #13 |
Good lookin out scoti!
Posted via Mobile Device |
09-23-2010, 02:53 PM | #14 |
Well, he called me back & found out that the 'new' u-bolts are for disc equipped trucks & he has a drum x-member so they're too big. I'll get him one of the smaller dia ones so he can get going again tonight.
09-23-2010, 04:14 PM | #15 |
Slow Old Timer
U da man! That, my friends, is what makes this board so utterly fantastic!
09-23-2010, 08:36 PM | #16 |
Either should have worked, the bigger ones just need to be smacked sideways with a hammer a little. BUT, when I did my disc swap, I compared the drum-smaller U-bolt to the disc-bigger U-bolt.
The older U-bolt was of a harder material. The "old" bolts cleaned up and looked like new, no pitting, perfect. The "new" were pitted badly and did not clean up at all. After I adjusted the bigger U-bolts, I did the same hammer tap to the old U-bolts. The new bolt bent just enough, the old bolts just bounced the hammer. I did a simple hardness test with a hammer and punch, again the old U-bolt showed up as harder. I used the old U-bolts. They were just better.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
09-23-2010, 09:01 PM | #17 |
SCOTI came through big time great guy thanks again. I just could not see myself setting in a parking lot drilling through a frame with a cordless drill trying to get the 9/16 to fit.
