09-23-2010, 10:20 AM | #1 |
tie rod ends,72 ?
72, 1/2, short, fleet, with power steering. 1.25 rotors. i installed ccp 2.5 drop spindles everything hooked right up no problems. i thought i would install new tie rod end and sleeves before i got the truck aligned. i ordered everything for a 72. well, the 72 stuff is too big for the drag link and the spindle. today i ordered everything for a 70 to see if it fits. any insight?
09-23-2010, 10:29 AM | #2 |
Re: tie rod ends,72 ?
I had the same problem on my 71 with stock height (stock spindles). I tried two different brands of tie rods (Mevotech and Auto Extra) and neither of them fit because they were both too big for the spindles. I ended up getting the more expensive 71' moog tie rods and they fit perfectly. Worked for me, maybe trying a different brand could help?
1971 C10 Cheyenne Super Build Thread Here: http://67-72chevytrucks.com/vboard/s...d.php?t=411867 |
09-23-2010, 10:59 AM | #3 |
Some of CCPs drop spindles use 73-87 tie rod ends at the spindle. Also 73-87 upper ball joints & stock lower ball joints.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-23-2010, 11:07 AM | #4 |
new 72 ball joints worked just fine. and so did the original tie rod ends.
09-23-2010, 08:28 PM | #5 |
This is normal. The factory disc brake spindles take larger tie rod ends than the drum spindles. The common fixes are to either use the 71-up center link or buy a dual-size adjusting sleeve from vendors like CPP or Performance Online.
Ray Last edited by raycow; 09-23-2010 at 08:32 PM. |
