A day should have 30 hours.
Lifting Cab, Doors, Front Fenders, Hood and Rad Support off frame in one piece ???
Just like the name says, I somehow think this is a bad idea.
But I thought I better ask Thanks |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Lifting Cab, Doors, Front Fenders, Hood and Rad Support off frame in one piece ??
i think its a bad idea too.. you can pull the nose off in one piece but id pull the nose as aunit then the doors remove the seat and then lift the cab
I just did not want to go thru the hassle of unbolting everything. The interior is already out. Same with electrical.
I have a 1 ton overhead crane at my shop which I was going to utilize |
Getting Old; Going Broke
Take the hood off, wrap straps through the cab and around the core support, like through the headlamp holes or something. Should be fine as one unit going straight up and straight back down, just be sure to not try to do it by just lifting the cab or something.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
It's only 3 bolts per side that hold the fenders to the cab. Pull the front clip as one piece and pull the cab seperate.
![]() Join Date: Apr 2009
no u can keep doors on to pull the fenders.but it easer to remove fenders with front bumper off
Posted via Mobile Device |
Happy to be here
![]() Join Date: Mar 2000
I would never try it. If you don't lift equally your going to tweak everything and have to pull it all apart to get it straight again.
#9 | ||
Thank you for the input |
I did it on a couple with a cheap A-frame and a Harbor Freight winch. We used a couple of long straps, one all the way around the cab, toward the rear, held in place by the cab bolts. One more around the front fenders and the last one at the bottom of the core support. The core support piece and rear strap lift most, the one around the fenders is more for stability than anything else. We managed to get 'em high enough to roll frames out from under them without letting the air out of the tires, both were 1-tons with tall front tires!
This let me keep the entire front clip together, where everything has settled to after 150K miles of bouncing around. |
[QUOTE=canadian trucker;4206350]I believe you are correct sir. I stand corrected.
your welcome sir |
A made a lifting spreader beam and lifted the cab with straps as shown. I have since added the correct lifting hooks and lifting straps but this worked fine. I still need to pull the cab from the 86 and box off my 87. It works for the cab and box. The main advantage of the spreader beam it it does not squeeze the parts being picked up.
#13 | ||
Im liking both of these ideas. If I only could get my cab mounts...... unbolted that wold be great.
#14 |
GoatLube Experss
![]() Join Date: Oct 2009
Buick455 I like the way you think, your get'n your moneys worth outa that backhoe aint ya, feed'n cattle, body work, dig'n footers !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#15 |
resident wrencher
we did several with a skip loader with a three way bucket and a tow strap thru the winders and a guid roap for just the cab and doors full interiour and wiring and everything it went great we also move beds with this method i would take the clip off i had to use a leaf froma spring pack as a prying device to jummiy it off the frame the bumper helped as a fulcrum point and no damage to it if done right no damage shopuld occur
| Bookmarks |
