HELP!! Lifter Problems
Ok so when I bolted on my new head, I had all the rockers installed and adjuster, got the engine running, etc, etc...I hooked up a vacuum gauge to it recently, and noticed the gauge was jumping, so I think, must be a valve out of adjustment. When I pop the valve cover off, I notice one of my rockers is free as a bird, and my pushrod has fallen down...I obviously have a collapsed lifter correct? I'm running a 250 inline...I've read that I would need to replace ALL lifters AND camshaft if I have to replace one...is there any other solution??
I've also read that perhaps I just have a clogged lifter, and perhaps it can be remedied...in order to get to them, i'd have to take off the push rod cover on the side of the block correct? Would I need to drain off any coolant to do this first? Someone please help, I was so close to being able to take the truck for it's maiden voyage, and now it seems i've taken 12 steps back. Thanks in advance! |
Re: HELP!! Lifter Problems
Unless you had a lobe go flat, there's no reason to swap the entire cam. Smear break-in goo on it and run break-in oil additive and break it in just like a new cam. Change the oil and filter, check valve adjustment and button 'er up.
Any other replies? What if anything can be done to salvage the current lifter?
Posted via Mobile Device |
![]() Join Date: Dec 2008
ask here http://67-72chevytrucks.com/vboard/f...splay.php?f=24 may get more help
| Bookmarks |
