Old 09-23-2010, 10:15 PM   #1
70shortfleet
70shortfleet's Avatar
Factory tach question
Does anyone know if a factory tachometer will work with an HEI distributor?
70shortfleet is offline   Reply With Quote
Old 09-23-2010, 10:28 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Factory tach question
yes...I had it on my blazer. There is a spot to run the tach wire on the distributor cap.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-24-2010, 06:10 AM   #3
Blazer1970
Blazer1970's Avatar
Just be forewarned that a factory tach will not be anywhere near accurate, no matter what kind of ignition you have.
Blazer1970 is offline   Reply With Quote
Old 09-24-2010, 03:20 PM   #4
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Not arguing, but why would you say that? They are both using the pulses from the coil for a signal. Why would one be more accurate than the other?
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 09-24-2010, 03:28 PM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
I can't agree with that statement. I have seen some that read quite accurate. I have also seen some that were not close.
To answer your question,
Yes it will work with an HEI.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-24-2010, 03:29 PM   #6
1970cstblazer
1970cstblazer's Avatar
Mine reads about 100 rpm too much throughout the sweep.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 09-24-2010, 03:49 PM   #7
red71cheyenne
Back in the sticks
Have you tried mechanically zeroing it? There is a zero adjust on the back.
2011 K1500 Suburban
2014 K1500 Pickup
Old 09-24-2010, 09:53 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I think what blazer1970 was trying to say, is these original tachs were inacurate 40 years ago, and are worse now.
Back to the original question, some people have had stock tachs that wouldn't work with the HEI, but in general, they usually work.
Old 09-24-2010, 09:59 PM   #9
sharpie1972
Mine works just fine up to 5k! Sharpie
sharpie1972 is offline   Reply With Quote
Old 09-24-2010, 10:32 PM   #10
Andy4639
Old member
Andy4639's Avatar
Talking Re: Factory tach question
The factory HEI setup has the terminal marked for a tach.
Mine works great for the past 20 some years on the HEI and it's as acurate today as it was when I bought it. These are 70's technolgy but very good I may say. I have had it hooked up to numerous machines and it was within a 100RPM of any one of them which is pretty dog gone good I'd say!
I even have a hand held tach to use back when I had the stock 307 in it and it always read the same.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
