Old 09-24-2010, 02:48 AM   #1
scrapmetalart
Junior Member
My cheap bedfloor / bedliner
has been in there for 3 years. found it in the dumpster. it is usually flipped over but I like this side for a bit
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 09-24-2010, 04:00 AM   #2
R.L.
R.L.'s Avatar
Re: My cheap bedfloor / bedliner
Cool I like it too.
R.L. is offline   Reply With Quote
Old 09-24-2010, 06:38 AM   #3
292farmer
292farmer's Avatar
nice, woulda been real cool it was an old automotive or gas station sign.
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
292farmer is offline   Reply With Quote
Old 09-24-2010, 08:59 AM   #4
Shane
Shane's Avatar
is it plywood?
Shane is offline   Reply With Quote
Old 09-24-2010, 11:20 AM   #5
Seraph
Seraph's Avatar
x2
1972 chevy c 10 longbed
2000 Ford Powerstroke (daily driver)
Seraph is offline   Reply With Quote
Old 09-24-2010, 11:31 AM   #6
marcsRX
68 C10 SWB
marcsRX's Avatar
Is that an upside down Harley sticker?
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman
marcsRX is offline   Reply With Quote
Old 09-24-2010, 01:01 PM   #7
Shane
Shane's Avatar
yes ...
Old 09-24-2010, 01:04 PM   #8
VDOG
Grand PooBaa Member
VDOG's Avatar
How cool that would be if you could work it in to be part of the bed floor.
VDOG is offline   Reply With Quote
Old 09-24-2010, 01:15 PM   #9
scrapmetalart
Junior Member
Originally Posted by Shane View Post
is it plywood?
YEp. Just painted plywood. Keeps me from beating the bed up anymore than it already is.
Old 09-24-2010, 09:29 PM   #10
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Hello scrapmetalalert, I have a similar bedliner! Mine is one panel from a multi panel billboard I tore down years ago. I like yours much better as a complete sign!
I slide it out a ways, pile junk on it slide it back in then reverse the process to unload my junk. Gets harder every year to climb up into a 3/4 ton so this makes some climbing in uneeded!
That hand painted plywood sign is most likely MDO-medium density overlay plywood that had 1 or both smooth grain free sides depending on the need, that made a nice surface for the sign painter to letter on after being coated with enamel base paints. Considerably more expensive than normal construction grade plywoods.
Thanks for the pic!
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 09-27-2010, 04:01 PM   #11
scrapmetalart
Junior Member
Nice 70GMC
It looks like a real nice piece of plywood. I bet youre right
Old 01-19-2011, 06:58 AM   #12
scrapmetalart
Junior Member
Im cutting my frame & going to a short fleet/wood floor bed & I might use this sign as the floor for a while...
