Old 09-24-2010, 11:05 AM   #1
rddaves54
rddaves54's Avatar
another question virbration????
I have a vibration at 45 miles an hour and it levels out or goes away around 55 miles an hour. I checked front tires, exhaust, motor mounts, u-joints, carrier center drive shaft bearing for tightness and they all seem good.
I was wondering if this has occurred for anyone else and what I might check next. I have had the truck finished and on the road (not much though) for about 12 months and when I first started driving it this was not going on.
When it goes to vibrate or shudder (I am not sure which) I can put it in neutral and it will stop and smooth out would this maybe be transmission related? I am going to look at transmission mount and see if it is tight.
Chief mechanic for my, 54 Belair, 64 Corvair, 72 C/10Fleetside and 2002Tahoe.
John 14:6 Jesus said, "I am the way, the truth, and the life. No one comes to the Father except through Me.
My Book "Why Cancer is Not Bad Luck" by WestBow press
rddaves54 is offline   Reply With Quote
Old 09-24-2010, 12:22 PM   #2
cdowns
cdowns's Avatar
Re: another question virbration????
i'd start with wheel balance
Old 09-24-2010, 02:47 PM   #3
Shaky
Six in a row makes it go...
Shaky's Avatar
If all else fails, check your harmonic balancer and make sure the outer ring didn't move relative to the inner.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
