Is a 4wd rearend the same as 2wd?
Are there any differences that may cause problems in a swap? Both are '72 model, both 8 lug 3/4 ton rearends, (Eaton, I believe) but one is out of a 4 wheel drive, and one is out of a 2 wheel drive. Both are leaf spring rearends.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com Last edited by HuggerCST; 09-24-2010 at 11:46 AM. |
![]() Join Date: Jan 2002
Re: Is a 4wd rearend the same as 2wd?
It shouldn't make any difference if they are both leaf spring rear ends.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
That's my thought too, I just wasn't sure about the length, shock mounts, driveshaft, etc.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
Shock mounts may be different but the width should be the same. The driveshaft may be different if the two trucks have different transmissions.
20' Daredevil (Ret)
![]() Join Date: May 2003
Both shock mounts are forward on my '72 K20 (Eaton).
![]() Join Date: Apr 2007
Spring perches will need to be moved. Sharpie
Member #1049
Sharpie is correct.. 2WD leaf spring rear ends have wider spacing than 4x4's on the perches due to the "bulge" in the rear frame rails
Although if its out of a longhorn.. they are the same as 4X4. |
Good info, thanks guys, that helps a lot.
