09-24-2010, 01:42 PM | #1 |
Junior Member
Enclosed Trailers
Do any of you folks use an enclosed trailer for your truck?
I was tossing around the idea of getting one and I found some good deals on them in Georgia (Hurricane cargo), Would be a heck of a drive from Texas. We have Pace and some other brands close by and the prices are not too bad. Really just curious if the truck would even fit in one and if there are any issues with using one. Thanks Keith
68 GMC 565 BBC Abruzzi super pro glide 9.85@135.00 |
09-24-2010, 02:51 PM | #2 |
Re: Enclosed Trailers
I have an 8.5 foot wide enclosed. The truck is a little tight going past the ramp cables and the inner fenders but it fits (approx. 1.5 to 2 inches on each side). Now that I have one I love it. Its quite a bit heavier than the open trailer but as long as you have a strong enough tow rig thats no problem
85 GMC toy Lowered, newer box swap, 350 .060 over with AFR 195s, forged pistons, TCI TH350 1.83 60' 13.14 @ 100 on motor 1.49 60' 11.52 @ 116 w/150 shot 1952 Chevy truck project 1980 Z28 Camaro 1967 Camaro drag car 10.60@126 |
09-25-2010, 03:17 PM | #3 |
Ive thought about the same thing for my 65 chevy swb when its done.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
09-26-2010, 12:59 AM | #4 |
I get approx. 3 mpg better with my open trailer, but enclosed is nice to work out of between rounds with a work bench, power generator/lights etc. or to keep things/race truck locked up inside on overnight trips or a place to keep both you and the hot rod out of not so friendly weather.... plus it can be used as extra enclosed storage/garage in off season!
Get the biggest trailer you can safely tow or feel comfortable towing...you'll be glad you did!
1970 c-10 short/step box morphing into street/strip 1967 RS/SS convertible Camaro 1932 Henry Ford steel 5 window coupe highboy hotrod 1931 full fendered model A sedan AV8 traditional hotrod. 1934 Ford 5 window coupe and a (pile-of-parts) 1929 Model A coupe, plus our "normal" people vehicles. |
09-26-2010, 10:37 AM | #5 |
I have owned a couple for my truck and it is really tight. My next trailer will have whats called ramp overs. These are ramps that go over the wheel wheels then you should have 6 or 8 inches on each side. You must get a 8.5 wide trailer for these trucks and it would be best to have a removable drivers door, an escape door in the side of the trailer or winch the truck in and out.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
09-26-2010, 11:49 AM | #6 |
Redefining LowBudget
also notice all these guys have trailers with round corners or a V nose!!! if its square it will tow like a brick!!!!..I have a 24 V nose and round corners...also be sure to get the BIG axles if its got 5 lug wheels on it I walk away...remember your hauling a truck!! so 2 3500lbs axles won't cut it when you add the weight of the truck and trailer your running way to close to the GVW of the trailer..which means a shorter trailer life.,tires frame and what not....spend a little more now or pay later...
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
09-26-2010, 12:08 PM | #7 |
Registered Truck Offender
My 66 SWB fits just nicely in my JimGlo.
Back the Nova out, drive the truck in, open the door and step out. The drivers side wheelwell comes off with 2 wing nuts and has to be put on before you close that big 'swing up' side door. But this thing is the berries!!!! http://www.small-block-chevy.com/trailer.htm
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 09-26-2010 at 12:10 PM. |
09-26-2010, 07:21 PM | #8 |
That's a wild trailer Marv. That is what I call an escape door.
Hot trucks I agree on the heavier axles being needed but I disagree on the v nose round nose stuff. I prefer a flat nose with an extended tongue so you can put a generator on the tongue.
09-26-2010, 11:00 PM | #9 |
Kevin I have the best of both worlds with my trailer its what they call a modified V it only covers about half the tongue I have a spare tire up front and I can still lower the tail gate
I think you mistook what I meant by round corners......if the trailer is a true square it will drag harder than one that has just the round corners pieces and roof
10-06-2010, 11:36 AM | #10 |
I used a friends 38' gooseneck 8.5' wide. I had to crawl out the driver's window around my funnycar cage. Not too bad when I still weighed 145 lbs. Might not be so easy now.
