Old 09-24-2010, 04:09 PM   #1
dag19
dag19's Avatar
Wheel hop
After I got done taking 2 leaves out of the rear of my 70, I mashed on the gas (after a few easy trips around the block) and the whole rearend of my pickup bounced all over the road. What do I need to do so this quits happening?
dag19 is offline   Reply With Quote
Old 09-24-2010, 05:16 PM   #2
raycow
Re: Wheel hop
You will need some type of traction bars. When you removed leaves you reduced the spring's torsional resistance, and now the axle housing is winding up the spring when you are putting torque through it. This is also bad for the rear U-joint.
Ray
raycow is offline   Reply With Quote
Old 09-24-2010, 05:28 PM   #3
cdowns
cdowns's Avatar
Re: Wheel hop
stop mashing gas pedal the resulting abuse stops
Old 09-26-2010, 04:25 PM   #4
Ronnny
Re: Wheel hop
Must be nice to have leaf springs. And i guess you took them out to lower the truck. Your springs got weaker and now you have wheel hop or also called axle wrap. If it were me i would put a spring back in and see if it cleared it up. I will asume your shackle is in the rear Put 1 or both back in and make a longer link on the shakle. It should be inverted if it is like the 73-and up trucks. So a 2" longer shackle will lower the truck about an inch. On the 4x4 trucks we would do a shackle flip to raise the trucks. You could also go for traction bars of a sort but would not really fix the problem just hid it. also could get the springs straightened at a spring shop or just look at overload springs and leave the 2 you took out out. Losts of options. If your springs are over the axle tube you could do a spring under conversion.
Ronnny is offline   Reply With Quote
Old 09-26-2010, 06:51 PM   #5
jrcaprai
Re: Wheel hop
http://www.calvertracing.com/caltracs.php
jrcaprai is offline   Reply With Quote
Old 09-27-2010, 02:30 PM   #6
dag19
dag19's Avatar
Re: Wheel hop
Haha that is easier said than done!!
Old 09-27-2010, 02:32 PM   #7
dag19
dag19's Avatar
Re: Wheel hop
Originally Posted by jrcaprai View Post
Daggum...those are nice but $400 nice?! Are there cheaper options out there? Didn't coil pickups come factory with traction bars? I can't recall. THANKS a lot for the link though, if I can't find anything out I will hit these guys up.
Old 09-27-2010, 02:36 PM   #8
dag19
dag19's Avatar
Re: Wheel hop
You are correct Ronny, I did take them out to lower it. I do enjoy the leaf springs for sure. Plenty of options with them. The problem with doing the shackle trick is I already have 3" drop shackles back there! And that is as low as I can go with that. What is this that you speak of with the overload springs? What would I have to do to fix it up with those?
Old 09-27-2010, 02:44 PM   #9
dag19
dag19's Avatar
Re: Wheel hop
So all this leaf spring talk brings up another question. When I went down to the local spring shop to have them build me a set of U bolts we got to discussing rear ends. He asked what I have, so I said a 70 1/2 ton. He said, "with leaf springs?" I said yessir. He said "no dice!" He went on to say that I actually had a 3/4 ton because all 1/2 tons up to 1971 had coils in the rear end. The 1971's and 72 1/2 tons were available with leaf springs. Can anyone solidify and clarify these statements? I took his knowledge and ran with it just because the old timer has been doin it for 50 years!! So any insight would help me out. THANKS!
Old 09-27-2010, 03:01 PM   #10
*Dylan
Mean Buzzin' Half Dozen
*Dylan's Avatar
Re: Wheel hop
Take everything you hear with a grain of salt. 3/4 ton trucks were not the only trucks to get leaf springs. Nearly all GMC trucks came with leaf springs, with coil springs being an option. Whereas nearly all Chevy trucks came with coil springs stock and leaf springs as an option. I do believe you could get leaf or coil on any truck and that it was not limited to just 1/2 ton or 3/4 ton. Take that with a grain of salt as well, because I'm only about 90% sure that it's right.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale)
1967 C10 SWB
Dylan
*Dylan is offline   Reply With Quote
Old 09-27-2010, 03:08 PM   #11
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Wheel hop
I think he needs to do some research, 71/72 chevys came with coils 71/72 GMC's came with springs.
All but the stock 70 (If I am right) GMC's came with springs.
All Chevys (If I am right) came stock with coils (67-72).
Chevy didnt drop the coils until the next body style (73-Up)
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 09-27-2010, 03:11 PM   #12
dag19
dag19's Avatar
Re: Wheel hop
Well see there is yet ANOTHER option that it could be!! Maybe it is a GMC 1/2 ton?! Haha I agree though I will take it all with a grain of salt. Can the VIN be decoded on these years of pickups?
Old 09-27-2010, 03:19 PM   #13
71meangreenc10
Re: Wheel hop
The only thing I see different in the VINS that tell you what type is the 72 models, maybe its just mine but my GMC's had a - in the VIN where my chevys never have.
Get a picture of the SPID, that will help.
Smitty
71 C30 Wrecker
Old 09-27-2010, 03:24 PM   #14
*Dylan
*Dylan's Avatar
Re: Wheel hop
It could be a Chevy 1/2 ton with the leaf spring option as well. What makes you think it could be a GMC? Unless you feel someone may have swapped frames at one time there shouldn't be much reason to suspect that. Like 71meangreenc10 said, a picture of the SPID may help.
Edit: Or I suppose someone could have swapped out front clips and tailgates as well. The VIN should tell you what you have though.
1967 C10 SWB
Dylan
Old 09-27-2010, 03:27 PM   #15
dag19
dag19's Avatar
Re: Wheel hop
Smitty
What is the SPID?
Old 09-27-2010, 03:27 PM   #16
*Dylan
*Dylan's Avatar
Re: Wheel hop
It's the sticker on the inside of your glovebox door. It shows all the options your truck came with.
1967 C10 SWB
Dylan
Old 09-27-2010, 03:28 PM   #17
71meangreenc10
Re: Wheel hop
Decal on the inside of the glove box door....
Service Parts Identification Decal....or something like that.
Smitty
71 C30 Wrecker
Old 09-27-2010, 03:28 PM   #18
dag19
dag19's Avatar
Re: Wheel hop
Nah I really don't believe it is a GMC cause that would be a lot of changing to do just to have a "chevy". Doesn't seem feasible. The previous owner had done a bit of work to it though...but nothing major.
Old 09-27-2010, 03:29 PM   #19
71meangreenc10
Re: Wheel hop
I am too slow...Lash me now....
Smitty
71 C30 Wrecker
Old 09-27-2010, 03:30 PM   #20
dag19
dag19's Avatar
Re: Wheel hop
Oh ok cool...I will check it out tonight. I know that it is fairly tattered and worn. I hope I can make out what it says...
Old 09-27-2010, 03:31 PM   #21
*Dylan
*Dylan's Avatar
Re: Wheel hop
Smitty
Haha sorry, I'm just sitting here killing time. Your answer helped me out though, I had no clue what the actual acronym stood for.
1967 C10 SWB
Dylan
Old 09-27-2010, 03:32 PM   #22
71meangreenc10
Re: Wheel hop
If you can read it the VIN will be on there too, it should match the door jam VIN, tell you the wheel base.......
Smitty
71 C30 Wrecker
Old 09-27-2010, 03:37 PM   #23
dag19
dag19's Avatar
Re: Wheel hop
Alright I will check it out. I know the VIN is on the door jam etc. I will study the glove box tonight. I hope it reveals this mystery machine!
Old 09-27-2010, 03:48 PM   #24
71meangreenc10
Re: Wheel hop
If you can read it, it should tell you everything, alot of people dont check the SPID when buying these trucks and it costs them $$$$....ie they buy a shortbed that has been cut down from a longbed and the PO told them it was a shortbed, the VIN has been changed and they didnt change the SPID = mystery truck. Lots of sneaky people out there and I have caught a couple.
Smitty
71 C30 Wrecker
Old 09-27-2010, 03:48 PM   #25
raycow
Re: Wheel hop
Beginning with 63, Chevy offered the option of leaf springs on 2WD, and you do find a few out there like that. Strangely enough, GMC offered the option of coils, and those trucks are really scarce.
Ray
