What Speakers Do You Use?
Hey,
I'm in the market of getting new speakers in my 05 Silverado and then putting the same speakers in my 77 later. I want something that sounds good. They are all going to be visible like in the doors or on the back of the cab so they should look nice...What do you all use and like? Thanks
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Re: What Speakers Do You Use?
The body man at my work had some speaker boxes in his 89 chevy dually that are designed to fit behind a chevy bench seat, so I took the measurements off them and built my own out of 3/4 inch particle board. It turned out pretty good. I put two 6x9s and one 8 inch kicker sub in the middle. I put a ported hole above each speaker, and a 800 watt sony xplod amp. Wayyy more than enough in a closed cab! Very good quality too! I'll give ya the dimensions for the box if you need. The passenger side of the box is closed off at the end, and the driver side is capped off about 8-10 inches in, and I screwed the amp inside the box inside that 8-10 inch space. Heres the pics:
Rich My first truck!! ![]() |
those speakers aren't sharing the same air space are they?
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
yes they are. I instantly thought of that as soon as I put it in and listened to it. The only thing in the box that isn't sharing the same air space is the amp. After thinking of that, I used a hole saw and drilled holes in the top to allow ventilation. Knowing what I know now, I think I would have installed separators between each speaker.
![]() Join Date: Dec 2008
Truck" Audio for Starters look at Big Tunes on a Small Budget
Master Procrastinator
JL audio in my boat and truck and planning on the amse for my 68, you get what yo pay for and on ebay they really aren't too bad.
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
ebay humm i can think of a lot better place to get Audio electronics bro crutchfield sonicelectronix.com ect..
>130dB Moderator
Arc Audio, and lots of it...
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. Last edited by AceX; 09-25-2010 at 03:25 AM. |
Geez, I would hope not.
Rock out with your, uhhh.... Hang out with your wang out! ![]() |
I know everyone says that subs sharing air space with your mids and tweets are bad, but what is exactly wrong with that? Before, I had my 6x9s AND my sub hooked to the amp. Now just the sub is hooked to the amp and the 6x9s are hooked to the speaker outputs on the back of the deck. What's going to happen if they share the same air space? Thanks (Not to jack your thread :P)
Well, one thing is... Sub is amped and the others aren't, if you turn up your amp and crank the deck, you might just end up blowin' the cones out the front of your speakers. Lots of air pressure in there, lookin' for a place to go. My little cousin' did it... "Dude, check out my new system!" ... **RIIIIP** blew the covers off of the 6x9's, cones and everything.
>130dB Moderator
Anything sharing airspace that dont have the exact same properties is a recipe for trouble. At lower levels it isn't so intense, but once things get bumpin, it won't take much to destroy speakers beyond the point of rebuild...
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
#13 |
jbl don't have pics of everything. just got some of it so its not installed got it all off CL
JBL P660C Component Speakers JBL GTO1214D sub had some MTX Audio but one was bad lookin for some door Speakers Last edited by nbpro; 09-26-2010 at 08:47 PM. |
