Old 09-24-2010, 10:36 PM   #1
red69ss
Burnouts are therapeutic
red69ss's Avatar
72 doors
ok so I repaired one of the 72 doors off a donor truck but the other 72 door is to far gone , I think I found a good original door but its not a 72 .so can I fill the screw hole for the vent window on the door I repaired already if I'm going to use the 72 vent windows? this way both doors match ,is there much diff. between 68-71 vent windows and 72 ones?.....not sure which direction I'm going yet vent window vs. one piece just trying to figure out which doors I'm going to use , I had 7 doors and only one is realisticly repairable.......... I'm thinking this will work just looking for reassurance from the experts.(hope I explained this clearly enough)
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 09-24-2010, 10:54 PM   #2
BIG ORANGE
BIG ORANGE's Avatar
Re: 72 doors
Weld up that hole in the 72 door and dont look back! Which door do you need to have a good set of 72's?
Thanks for the heater resistor the ole guy was as happy as he could be!
We workin on the 69 to morrow, drop by if you can.........
later dude!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 09-24-2010, 11:21 PM   #3
sameyrasmea72
sameyrasmea72's Avatar
Re: 72 doors
Originally Posted by red69ss View Post
.....if I'm going to use the 72 vent windows? this way both doors match ,is there much diff. between 68-71 vent windows and 72 ones?......(hope I explained this clearly enough)
The difference is in the doors only. There should be no difference in the 1968-1972 vent windows.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 09-24-2010, 11:25 PM   #4
red69ss
red69ss's Avatar
Re: 72 doors
I need a pass. side door, but I will likely delete that screw indention even if I do come up with another 72 door, I figured it wouldn't hurt anything meant to ask you this yesterday it just slipped my mind. ... no problem on the HR , dads coming over to straighten me out on the body work tommorow but if I can get free I might come by...... and thanks!
1969 CHEVELLE SS
Old 09-24-2010, 11:26 PM   #5
red69ss
red69ss's Avatar
Re: 72 doors
thought so thanks for the clarification.
1969 CHEVELLE SS
Old 09-25-2010, 01:35 AM   #6
pat 70/71
pat 70/71's Avatar
Re: 72 doors
I bought a pair of 72 doors for my 71 (came of a dump truck) all vents & parts are the same in my opinion, they fit perfect with no problems at all and the vent window holes don't worry me none cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 09-25-2010, 03:58 AM   #7
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Re: 72 doors
Just the Door panels mount different on the 72's if you use a 68 door you will have to make the holes for the door panels for 72 door panels. I dont know how it would work if you were to go the other way around from a 72 door panel to a68 door panel. But there is a difference in the way they both mount to the doors... Hope I didnt make it too complicated I haven't sleept in 24hrs had to log on before I went to sleep
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
