Old 09-25-2010, 08:55 AM   #1
j_cst_10
j_cst_10's Avatar
Simple Brake Question (project update)
This may seem like a dumb question, but here it goes anyway. I am converting my 70 CST to power disc brakes and I was wondering...
Coming off of the proportioning valve, what side feeds the front brakes?
The fitting towards the rear of the truck (closest to the firewall) has the larger fitting. I would assume this to be it but on my CST now, the rear line feeds the rear brakes and front line feeds the front.
How my truck is set up now is usually the convention, is it switched on disc brake C10's?
j_cst_10 is offline   Reply With Quote
Old 09-25-2010, 09:09 AM   #2
MikeB
MikeB's Avatar
Re: Simple Brake Question (project update)
OEM or aftermarket prop valve? Do you have a picture?
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-25-2010, 09:42 AM   #3
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Do you have a drum/disc proportioning valve? Usually the larger fitting (rear facing on most) feeds the rear and either (or both front) feed the front calipers.
TobyArnot is offline   Reply With Quote
Old 09-25-2010, 11:04 AM   #4
j_cst_10
j_cst_10's Avatar
I will post a pic. It is a factory prop valve.
The reason I am unsure about all of this is because the disc brake flex line accepts the 1/4" brake fittings (larger) while the prop. valve has the 1/4" fitting towards the rear and the smaller 3/16" fitting towards the front.
I am just wondering why the flexible brake line for disc brakes takes a 1/4" line if the prop valve is 3/16" on the front and 1/4" for the rear??
**Drum/disc prop valve
Old 09-25-2010, 11:28 AM   #5
13lazer
13lazers' blazers
13lazer's Avatar
The larger reservoir on your master cylinder should be piped to your disc brake calipers. I had to run different diameter lines on my 70 blazer when converted it to disc brakes. I'm not 100% sure, but I think the pipe diameter should be left the way GM designed them.
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 09-25-2010, 11:35 AM   #6
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
What mastercylender/booster combo are you using? Factory for a disk/drum truck or factory for a drum drum truck? Either way the rear resivour is for the rear brakes and the front one is for the front. If you are using a drum/drum set up, you will need to at the very least add an adjustible proportioning valve in the line going back to your rear brakes. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-25-2010, 02:27 PM   #7
MikeB
MikeB's Avatar
It's not very pretty, but here's a nearly stock setup from a 71-72.
As you can see, the front circuit uses 3/16" line; the rear 1/4" from M/C to prop valve to tee fittings.
Mike
Old 09-25-2010, 07:29 PM   #8
j_cst_10
j_cst_10's Avatar
Thanks MikeB, that helps a lot.
That is pretty much what I thought it was going to be (conventional). What I still don't get is that my flex line to my caliper takes the larger 1/4" line, while the prop valve/master cylinder is plumbed with the smaller 3/16". (This is using factory DISC brake parts, not my original drum)
Oh well, I guess I'll have to make it work somehow.
Old 09-25-2010, 08:36 PM   #9
68anniversary
Unless I'm wrong your front 3/16 line comes off the front of the prop valve and goes down into a "T" fitting on the drivers side frame with one offshoot line going to the drivers side hose and the other line off the "T" continues across to the pass side hose. Those front lines are 3/16. That rear line coming off the prop valve just follows along side the 3/16 line across the front crossmember and then heads rearward to a fitting, then on to the rear of the truck. I just worked on mine tonight and this is how it was setup. Hope this helps
68anniversary is offline   Reply With Quote
Old 09-25-2010, 09:12 PM   #10
ERASER5
ERASER5's Avatar
FYI, Since no one has specified C10 or C20, MC plumbing for a C20 is reversed from a C10.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-26-2010, 08:36 AM   #11
j_cst_10
j_cst_10's Avatar
Well did they send me the wrong flexible brake line to the calipers? The fittings are definitely 1/4", not 3/16".
** Just checked the catalog and I ordered the correct part. This is a mystery, and not a good one. I just dropped my now lowered/disc brake converted truck on the ground and I want to drive it! All that is left is to bend a few brake lines.
Old 09-26-2010, 09:49 AM   #12
RCbowtie69
RCbowtie69's Avatar
I brought my disc brake system from MP brakes, but others are out there,CPP,i did disc to drums,they will know what proportion valve you'll need,you can check them on line
RCbowtie69 is offline   Reply With Quote
Old 09-26-2010, 12:49 PM   #13
j_cst_10
j_cst_10's Avatar
I am using the factory disc brake proportioning valve off of a 72 C10
Old 09-26-2010, 04:07 PM   #14
Pont406
there is a T where both front line come together. I am using inline tube kit but changed to 73 and up hoses. From what I remember I had to get an adaptor for the right side when trying to use 72 hoses but again it was for inline tube kit. Do hoses fit the lines? Which kit are you using? Here is a pic. Hope its helps.
Pont406 is offline   Reply With Quote
Old 09-28-2010, 01:08 AM   #15
j_cst_10
j_cst_10's Avatar
I ordered 71/72 flexible line and I am using a master cylinder/prop valve off of a 72 C10 that I parted out for the disc brake set up.
The flexible line is set up for 1/4" line while the prop. valve is set up for 3/16".
This seems like a fairly unique problem. Maybe I should just call LMC truck and ask them why these lines are set up for 1/4 rather than 3/16 if that is factory.
