Old 09-25-2010, 10:56 AM   #1
JayE72
fuel tank sending unit
Greetings everyone! Thank you in advance for your help and insight. I'm having a problem with my gas gauge on my 1972 Cheyenne 350, SB, A/T. I was reading several post related to this matter and noticed that I should have a ground wire attached some where to the sending unit or fuel tank. Can anyone help me with a picture of what and where the ground should be attached to? Thank you.
JayE72 is offline   Reply With Quote
Old 09-25-2010, 11:55 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: fuel tank sending unit
If you are referring to a ground strap, there's none used on the tank or sending unit. The tank itself is self grounded to the frame with the bottom bolts.
What sort of problems are you having? I'll look for the info on how to check it and post it shortly -unless someone has it readily available.
68gmsee is offline   Reply With Quote
Old 09-25-2010, 12:01 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Hrere is the site.
http://www.6066gmcguy.org/Electrical-02.htm
Old 09-25-2010, 12:12 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
The tank does not have a ground strap. It is grounded to the cab through the mounting bolts. You need to expain the simptoms so we can help you figure out your problem. If you want to find out if your sending unit is working, then you need to pull it and hook it up to an ohm meter. If it reads "0"ohms at its lowest point and "90" at it highest, then the sending unit is not the problem. While it is out you will be able to check the float to make sure it is not full of gas. You just work your way back to the gauge from there. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-25-2010, 12:51 PM   #5
cdowns
cdowns's Avatar
tho the tank is supposed to ground with the mounting bolts(so is the rear bed HAHAHA) i've run ground wires to the body as a backup to make completely negative that i have solid grounds in place
the only time its bad to run a groud is if you're in a boat
Old 09-25-2010, 02:46 PM   #6
JayE72
The gauge is pegged past full. The owner that had the truck before me had removed the wire to the sending unit. I got a new one (wire) and hooked it up. The gauge moved closer to the F line but it is still out of the range of the gauge. I tried to ground the gauge about 8 months ago it went to E but I burned an electrical run on the board. I repaired the burned piece. I have a backup gauge cluster perhaps this will work?
JayE
Old 09-25-2010, 06:46 PM   #7
De Fuego
De Fuego's Avatar
I have the same issue. My needle was pegged way past the F.. I found a loose ground wire. This fixed it and the gas gauge worked temporarily. Now all of a sudden its stuck past the F again...Sorry. No help here
De Fuego is offline   Reply With Quote
Old 09-25-2010, 11:05 PM   #8
Zoomin
Man of Mini-Talents
Zoomin's Avatar
The is a brown (tan) wire that runs from the tank to the wiring harness in the fuse block, which in turn goes to the fuel gauge via the instrument panel harness, then to the printed circuit, and finally to the gauge. NOTE - this wire is not supposed to be connected to a power source!
The sending unit acts as a rheostat, causing the needle on the gauge to register how much current is being allowed to pass through. When the needle is pegged past full, that means your brown wire isn't conducting between your sending unit and gauge. You could have a bad printed circuit in the back of the gauge panel.
Zoomin is offline   Reply With Quote
Old 09-26-2010, 01:01 AM   #9
JayE72
Thank you Zoomin. When I bought the truck the needle was already pegged. The wire was missing. I put a new wire on the sending unit and it didn't change much. It went from way past F to close to F.
Thanks Classic Heartbeat. Do you carry the fuel sending unit on your website?
Thanks to 68gmsee.
Thanks to all that responded to the thread!
