Old 09-25-2010, 11:27 AM   #1
WIDESIDE72
WIDESIDE72's Avatar
48 GMC 1-1/2 ton to 55 1st series 1/2 ton door interchange question
Is it possible to install 1948 doors on a 1955 1st series? I have a 55 Chevy 1st series 1/2 ton, and the doors are so-so rust wise, and need new glass. My dad has a 1948 GMC 1-1/2 ton flat bed with pretty nice doors. I was thinking that a lot of the 67-72 guys pay a lot of $$$ to go to one piece door glass, I would see if I could do it on the cheap. I am putting the truck on an S10 frame, so originality is not an issue. I figure since the truck is going to have A/C and I probably wouldn't use the wing windows much, the one piece windows would help eliminate a possible source of wind noise.
WIDESIDE72 is offline   Reply With Quote
Old 09-25-2010, 12:52 PM   #2
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
Re: 48 GMC 1-1/2 ton to 55 1st series 1/2 ton door interchange question
You have to change the striker plates too because the latches are different.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 09-25-2010, 02:12 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
I wonder if it is possible to swap the 48 door handles out for the 55's so that I have the push button door handles instead of the twist style (?)
Old 09-25-2010, 02:13 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
On a related note, does anyone know if I could put the early one piece glass and regulator into later doors that originally had two piece glass?
Old 09-25-2010, 09:49 PM   #5
Steve@OldSub.com
Anything is possible, but I believe a door handle swap would be a lot of work.
There are single piece glass kits on the market. If you want to keep the push button door handles you may need to look at those.
Steve@OldSub.com
Old 09-28-2010, 12:34 AM   #6
99 to Life
99 to Life's Avatar
48-50 obviously had one piece glass, which used different window
regulators than 51-55. You can swap out the vent, as people do it but you would need new regulators. As far as any other differences in the doors, I am not certain of but suspect there shouldn't be an issue doing the handle and glass.
If you think of it, they come from the same molds so whatever is in the inside should be interchangeable or customized.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
