Old 09-25-2010, 11:56 AM   #1
supersean1967
292 engine to a 283 setup
would swapping my 292 for a 283 be worth it and would this be an easy swap i already have a 283 i took from a 56 belair and it is just sitting around would i be able to just bolt this in to my original bellhousing and 3 speed tranny...
very new to this
supersean1967 is offline   Reply With Quote
Old 09-25-2010, 12:00 PM   #2
'72customdeluxe
Re: 292 engine to a 283 setup
Yes, yes, and I'm not sure about the trans. An all factory parts swap
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 09-25-2010, 04:49 PM   #3
raycow
If the engine came out of a 56 car, make sure it has holes for side mounts. You will need to replace the the passenger side frame bracket and relocate it to the rear set of holes. Your 292 bellhousing and flywheel will bolt up.
Ray
raycow is offline   Reply With Quote
Old 09-25-2010, 05:50 PM   #4
llowlife
283 clutch bellcrank hole tapped and same size bellcrank?
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot.
I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace...
72 short step w/ 388 /4l80e/ and 3.08 gears.
llowlife is offline   Reply With Quote
Old 09-25-2010, 06:14 PM   #5
71swb4x4
71swb4x4's Avatar
What are you looking to gain? If there isn't anything wrong with the 292 it's a stout engine with a lot of power.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-19-2010, 10:03 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I'm thinking of doing the same thing.
Swapping out the 292 in a 66 Chevy with a 65 283.
The 292 is cracked but runs.
Can any older model 283, 327, or 350 bolt up to the bellhousing that is presently connected to my 292?
66 C20 Service Truck:
Old 10-19-2010, 10:52 PM   #7
padresag
very new to this
they didn't have 283's in 55(265 cu"),but it may have been transplanted, which 50+ years anything can happen. those early motors mounted from the frt of the eng and didn't have the provision in the side of the block for side mounts. if it has the 3 bolt mounting pattern on the side you will have no problem. as Ray says you will need a passenger side frame tower from a 230-250 or 283 eng. the 292 was a different tower. http://www.persh.org/pickup/IdeaPage.htm. check this link. the pics will show you the difference.
the z bar are the same for both engs but you will need to acquire a threaded ball stud for the v8. you can buy those new. the 292 has a brkt w/welded ballstud which attaches to the block. besides the b/housing interchanging so will the flywheel from the 230-250-292 and 283
ron
padresag is offline   Reply With Quote
Old 11-03-2010, 11:27 AM   #8
LostMy65
LostMy65's Avatar
Is the Flywheel the same on the 292 as for a small block V8?
Old 11-03-2010, 01:05 PM   #9
raycow
I have read that some 292 cranks/flywheels were drilled for 1/2" (instead of 7/16") bolts, but I have never actually found one like this. Apart from that, the 292 flywheel is the same as the pre-86 V-8 (two-piece seal).
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
Old 11-03-2010, 01:39 PM   #10
LostMy65
LostMy65's Avatar
Thanks Ray
Old 11-03-2010, 02:58 PM   #11
72freak
Rottenwood Garage Member
72freak's Avatar
The bellhousing should be the same.....however when you drop that V-8 in the hole and bolt it to the 3 speed transmission it is going to sit back about ????5??? inches and the distrubutor will be right on the firewall and you will have to lengthen your radiator hoses and the fan will sit back and in my opinion it does not look good. To do it correctly you need to move the tranny forward and lengthen your driveshaft and move the x-member that is rivited in.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 11-04-2010, 07:55 PM   #12
LostMy65
LostMy65's Avatar
does anyone know which engine weighs more; the 292 or V8 350?
Old 12-04-2010, 11:31 PM   #13
LostMy65
LostMy65's Avatar
Ray
Isn't it ironic?
I just happen to have a 292 with the 1/2" Flywheel mounting bolts.
I'll take some pics and post them here.
Old 12-05-2010, 12:05 AM   #14
raycow
I see that nobody answered your question from a month ago. The 230/250 engines weigh about 450 pounds fully dressed. The 292 weighs somewhat more than those because of the taller block, but I would still expect it to weigh less than a SB.
Ray
Old 12-05-2010, 02:01 AM   #15
LostMy65
LostMy65's Avatar
Thanks.
Here's the 292 Flywheel with the 1/2" mounting bolts.
It does have 168 teeth, and is 14" dia. standard.
Old 12-05-2010, 02:14 AM   #16
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Mine is mounted in the rear holes (350 mounted with I6 towers). You can still get the dizzy in and out, but it is close (prolly could even use an HEI). To adress the fan and hose issues you can use the upper rad hose and the fan shroud out of a 4WD, since they sit back too. Here are some pics of mine so you can see what it looks like
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-05-2010, 01:45 PM   #17
raycow
LostMy65, could you please look at the starter mounting holes on your 292 and see if it has 2 holes or 3? And, if it has only 2 holes, are they straight across from each other or staggered? Thank you.
Ray
Old 12-05-2010, 03:19 PM   #18
LostMy65
LostMy65's Avatar
Flywheel Bolt Size Difference:
Starter Mounting Bolt Holes:
292 Crank:
Numbers on Block ( '13' at left of freeze plug and 1970 at right of freeze plug):
Old 12-06-2010, 08:21 PM   #19
LostMy65
LostMy65's Avatar
it appears that I can use either starter.
Either the one that bolts to the V8 block, or the one the uses three bolts to the bellhousing.
Old 12-06-2010, 10:59 PM   #20
raycow
LostMy65, thank you for posting the pics. I probably should have asked that question in a better way. What I meant was the starter mounting holes on the 292 block.
Ray
Old 12-06-2010, 11:07 PM   #21
LostMy65
LostMy65's Avatar
I'll have to dbl check, but I don't remember starter mounting holes on the 292 block.
The starter for the 292 was mounted to the bellhousing.
Old 12-07-2010, 02:38 AM   #22
raycow
The starter bolts to the bellhousing on manual transmissions, but on automatics it bolts to the block.
Ray
Old 12-07-2010, 02:49 AM   #23
LostMy65
LostMy65's Avatar
Ray
Ray
Ray
I guess I'm confused then.
I thought we were talking about flywheels being the same on a 292 as a V8.
You mentioned that you heard of some flywheels having the larger 1/2" mounting bolts, but never saw one yourself.
I posted pics showing I just happen to have one.
You then asked about holes for mounting the starter.
I don't think we ever were talking about auto trans.
My 292 with a manual tran has the starter mounted to the bellhousing.
If there is any other pics you'd like me to provide, I can post those tomorrow.
Old 12-07-2010, 03:08 AM   #24
LostMy65
LostMy65's Avatar
Okay, I think I see what you mean now.
This thread: http://www.67-72chevytrucks.com/vboa...d.php?t=362440
is on the subject regarding my question on using either starter.
It appears I can use either starter with my V8, but the bellhousing would have to be modified to use the starter that bolts to the block.
Old 12-07-2010, 12:34 PM   #25
raycow
Sorry to be causing so much trouble. My interest is in seeing the starter mounting holes on your block, or at least to find out if it has 2 holes or 3. This is on the block, not the bellhousing. I understand that you aren't using those holes for your application, but the engine should still have them.
I am trying to put together a starter/flywheel combination for an application that does not have mounting holes in the bellhousing, and I need to find out if the engines with 1/2" flywheel mounting holes are drilled differently from the ones with 7/16" holes. Thank you for your help with this.
Ray
