Old 09-25-2010, 08:14 PM   #1
66_k10_manny
leaky differential
Im leaking gear oil out the rear of the front differential where the driveline connects to the yoke. Whats the name of the seal there? Haven't taken it apart yet, went to autozone and they couldnt find the right part.
66_k10_manny is offline   Reply With Quote
Old 09-25-2010, 08:41 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: leaky differential
Pinion seal?
Old 09-25-2010, 10:24 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Pinion seal?
That's what I would call it....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 09-26-2010, 06:46 PM   #4
Davetopay
Not fun.
Davetopay is offline   Reply With Quote
Old 09-28-2010, 12:22 AM   #5
'63GENIII
'63GENIII's Avatar
Yeah it's the pinion seal. Just did mine 2 months ago. Not too terribly hard to do. Just be careful not to overtighten the nut. Otherwise it's just another seal
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 09-29-2010, 09:29 AM   #6
66_k10_manny
Im gonna try replacing it this weekend. . . .
Old 09-29-2010, 12:38 PM   #7
67mater
67mater's Avatar
you should swap the fluid while you're in it!!
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 09-30-2010, 01:16 AM   #8
'63GENIII
'63GENIII's Avatar
Definitely change the fluid. Make sure how much to tighten it first though. Too loose = bad too tight = also bad. Just the way it was when you took it apart = happy differential. It's not difficult, just have to pay attention.
Chris
'63 k15 long step
