09-25-2010, 10:14 PM | #1 |
Still plays with trucks
Great day at the wrecking yard
I scored some great stuff today at the wrecking yard.
Got a dash mounted delay wiper switch with delay module & pigtail for $3 out of a 79 that should give me the badly needed delay wipers in my 78 with little work. Scored a small tail gate band for all of $5 The dealer emblem on it came off easily with no damage to the band. One very tiny needle sized ding that should come out pretty easily, otherwise it just needs some fresh paint to make it perfect. Found a small fuel gauge still in a truck that used to have a factory tach. Unfortunately the hack who grabbed the tach butchered the housing to get it out so it wasn't any good and they ruined the printed circuit too. Scumbag hackers at the yard need a whoopin sometimes. Fuel gauge cost a big $2 Scored a near perfect 74 deep grille shell complete with 350 emblem. Only damage is one mounting screw flange is cracked just a little bit. Just needs a tiny bit of epoxy to solidify the one mount. The rest is flawless. I will probably fix it and sell it but might keep it and see how I like the looks on my truck. Got a good in pan wire harness and about two feet of the external wire harness for my 4L80E to replace and upgrade the damaged connector on mine. The in-pan harness runs for over $100 to get a replacement and the guy at the yard gave it to me for free! Woo hoo. Now the 4L80E can go into my 68 Camaro to tame down the gearing and give me full control over the shift characteristics. Got the 16197427 PCM out of the 4L80E harness donor too for $9 and that included the PCM carrier I yanked out of a whale Caprice that mounts the PCM to the kick panel. The same van I got the PCM & trans harness out of also had a beautify condition two button power window switch plus the matching single button passenger side switch and one perfect power lock switch that I scored for $6 Not a bad day at the yard.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
09-25-2010, 10:19 PM | #2 |
Re: Great day at the wrecking yard
Good scores! That wiper switch looks like the one in my 83. Wonder if it would drop into my 77.... I miss the delay wipers!
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
09-26-2010, 01:30 AM | #3 |
At the body shop.
68TT
ive got a 454 emblem for a 73/4 grille that needs a home.
" That didnt make it any newer " " Dont antique the equipment " |
09-26-2010, 06:51 AM | #4 |
Addicted to Rust
Interested in selling the fuel gauge? Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
09-26-2010, 08:07 AM | #5 |
nice scores
86 Suburban 2WD = rolled it and totaled it 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
09-26-2010, 07:12 PM | #6 |
You are very lucky. Around here the automotive recycling centers want almost as much or more than new prices for everything - if you can find anything. Plus, anything plastic, rubber, or electronic is fried in the AZ heat, so it should be worh less than elsewhere. On the plus side, the sheet metal parts and whole trucks are generally rust free, but rarely straight. Whole squares are like $2500 -$4000 for decent looking bodies.
09-26-2010, 11:57 PM | #7 |
I was told that to convert to the delay wipers you also have to have the delay wiper motor to go with the switch. Is this what you plan on doing or is there a way around that?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
09-26-2010, 11:58 PM | #8 |
Good scores
09-27-2010, 10:42 AM | #9 | |
Got to have patience. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
09-27-2010, 02:46 PM | #10 |
Not right now as I have plans to use it on my 78 but I will keep you in mind if things change.
09-27-2010, 02:55 PM | #11 |
I wish I had the 454 to go with that emblem of yours. The 350 emblem on there matches my 78.
09-27-2010, 02:58 PM | #12 |
Several sources have told me that the motors are the same and all you need is the switch & delay module. I ran out of time this weekend so I didn't get it installed to find out for sure. I will take some pics and verify for sure if it is just that simple.
09-27-2010, 03:10 PM | #13 | |
I had planned on using a cluster housing with a clock but now I will use this small fuel gauge in place of the clock and build a secondary temp gauge for the location the old oil pressure gauge was and use it for oil temp instead. Could be trans temp instead if I had an automatic.
09-27-2010, 03:43 PM | #14 |
Slots go on anything!
What is that speedo out of?
1974 Jimmy- 5.3/4L80e/NP241 |
09-27-2010, 04:19 PM | #15 |
I made an overlay for the Camaro tach to make it fit the shape of the truck dash bezel better and made a matching overlay for an 85 mph optical VSS speedo while I was at it. I was planning on converting the truck to TBI and needed the VSS output for it. I just decided to get rid of the KPH markings and change the numbering to even 10's instead of on the 5's like stock to match the Camaro tach. There was room to change the range to 90 mph so I did it.
I made the numbers larger and only single digits on the Camaro tach overlay so it looked more like a monster tach than the stock Camaro tach does. Below is a pic of the stock Camaro tach for comparison.
10-01-2010, 09:48 AM | #16 |
Addicted to Rust
Cool. Jay
