as any one done weather striping??
iam doing the weather striping in my 61. and did the weather striping on the cab and iam not sure were it starts and stop. i tryed one way and now the door will not shut. can you guys send pics.
Re: as any one done weather striping??
i just did mine started at the middle of the sill plate and worked my way around adding glue as I went and taping the rubber down with blue tape.
Senior Enthusiast
Not being able to close the door on new gaskets is very common. A lot of people have to reset the door latches a bit looser (for a while) with new gaskets until they take a set. Also be sure to v notch the joint where the two ends meet at the bottom. This lets the air out of the gasket so it can compress/collapse correctly.
