09-26-2010, 12:11 AM | #1 |
'68 5.3L Build
Well here is some pics of what I did today.
Here is the dirty heads and under the intake. Here is painted valve covers and under the intake plate Here is the Edelbrock intake and Carb Here is the Edelbrock coil covers But what the heck is this? It goes under the intake. Do I still need it? Now that the warmer weather is here. I just rolled out the frame and cab. Here is the floor being cut and prepped for the new floor. It will be sand blasted this week.
68 c10 350/th350 winter daily driver 90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver "Just so we are reminded of those who are held back, Up front there ought to be a Man in Black". Johnny Cash. Last edited by 6D8_C10; 02-19-2011 at 12:42 PM. Reason: Added new pics. |
09-26-2010, 11:27 AM | #2 |
Re: '68 5.3L Build
Looking good..
Sorry can't help you ID that part.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
09-26-2010, 01:24 PM | #3 | |
Re: '68 5.3L Build
09-26-2010, 01:35 PM | #4 |
Re: '68 5.3L Build
Correct.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
09-26-2010, 01:44 PM | #5 |
PROJECT 7DEUCE
Re: '68 5.3L Build
Looking good but yes you gotta install steam vent..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-26-2010, 01:52 PM | #6 |
Truck and auto performance nut
Re: '68 5.3L Build
that steam line looks bigger then what I have. On mice the rear ports are sealed...only the front ports go to the steam vents.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
09-26-2010, 03:24 PM | #7 |
Re: '68 5.3L Build
I believe the truck engines block off the rear ports and the car engines use all 4 ports?
09-26-2010, 03:38 PM | #8 | |
Re: '68 5.3L Build
Mine has 4. Its from a 99 Silverado 5.3L
68 c10 350/th350 winter daily driver 90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver "Just so we are reminded of those who are held back, Up front there ought to be a Man in Black". Johnny Cash. |
09-26-2010, 03:43 PM | #9 |
Re: '68 5.3L Build
Hey Alien,
I was reading over your links. It looks like the accessory brackets can interchange between the truck and the car Gen III motors. I like the GTO brackets with the alt down low and the power steering pump up high. Because the alt bracket is in the way of my coil cover. Will this work or is the another bracket system that is NOT in the way like the truck bracket is?
09-26-2010, 03:52 PM | #10 |
Re: '68 5.3L Build
Sorry I don't have an answer for you. I would check over at LS1Tech, the have a conversion and hybrid section with many knowleageable people that may be able to answer that question.
09-26-2010, 04:24 PM | #11 |
Re: '68 5.3L Build
I had thought I had read the car engines had 4? My 2005 5.3 from a suburban only has the front 2? Maybe it is a year thing?
09-26-2010, 04:52 PM | #12 |
Re: '68 5.3L Build
i think around 01 or 02 they just used the front 2 steam ports, and blocked off the rears, but like eveyone says, you need to keep it
09-27-2010, 07:24 AM | #13 |
Re: '68 5.3L Build
Well I guess I will get the steam line, scrub it down and paint it before putting it back on.
I should be getting my ceramic headers this week and my trans crossmember.
09-28-2010, 07:56 PM | #14 |
Re: '68 5.3L Build
I got my new ceramic headers today!
So can someone tell me what this is for on the passenger side of the header. Do I still need to hook it up? It has a block off plate that came with it. Here it is on the old headers.
09-28-2010, 09:07 PM | #15 |
Re: '68 5.3L Build
If you change accessories you have to change the crank pulley too, they all have different spacing. I managed to piece together LS1 accessories for about $200 but I got lucky. They can get pricey. Are you running power steering too? If not there are some good home-brew alternator only set-ups with the truck stuff on ls1tech.com.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
09-28-2010, 10:42 PM | #16 |
Re: '68 5.3L Build
That's for the EGR tube to hook to, you don't need it unless you're going full emmissions on your swap, which most people from Missouri don't do. You can just block it off.
09-29-2010, 12:56 AM | #17 |
Big Red - Now its a SWB!
Re: '68 5.3L Build
Nice swap! Keep us updated.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
09-29-2010, 06:51 AM | #18 |
Re: '68 5.3L Build
Thanks ls1nova.
09-29-2010, 07:06 AM | #19 |
Re: '68 5.3L Build
Look'n good with the swap. With reguards to the accessory drive, quoting for ls1tech, "The thing to keep in mind is that the truck/F-body/Corvette all use different accessory spacing in regards to the distance from the pulley to the block, the trucks stick out the furthest, the F-body is in about 5/8 from that and the vette is in a little more. The total difference between all three is around an inch I believe, but it is enough to make obvious bracket issues if trying to mix and match parts" http://www.ls1tech.com/forums/conver...de-1500-a.html
02-19-2011, 12:51 PM | #20 |
Re: '68 5.3L Build
Well I decided to sell the 68 as is with running motor and trans.
I just got to find a buyer now. Instead i will fix up the 69 cab. Here is the tear down
68 c10 350/th350 winter daily driver 90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver "Just so we are reminded of those who are held back, Up front there ought to be a Man in Black". Johnny Cash. Last edited by 6D8_C10; 02-19-2011 at 12:51 PM. |
02-19-2011, 07:17 PM | #21 |
Re: '68 5.3L Build
Whats wrong with the 68? Where'd the 5.3 Go?
02-20-2011, 12:19 AM | #22 |
the boat guy
Re: '68 5.3L Build
good looking swap, but wats that funny looking thing between the valve covers?
get that truck running hope we get to see ya at magic dragon!
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
02-20-2011, 12:47 AM | #23 |
Re: '68 5.3L Build
Nothing wrong with the 68 LWB
I was going to just swap cabs. The 69 was a SWB frame. But, they both needed just as much work done on them. I figured I could get more out of the 68 if I kept it complete. I didn't think I should put a 68 cab with 69 front or a 69 cab with a 68 front. As far as the LS, it is going on the 69. Also I will return it to EFI and not do the carb.
02-20-2011, 11:05 AM | #24 |
the boat guy
Re: '68 5.3L Build
alot of people prefer the 67-68 front clip. So in theory I would think that wold make it more valuable. Many don't mind having a frankenstein truk as long as it has a good vin and title. Either way it's your truck build it how you want.
02-20-2011, 02:56 PM | #25 | |
Re: '68 5.3L Build
I ask on this forum before, and its seemed like a toss up which others preferred. Oh well, I like them all.
