1972 C/20
New Cab Mounts!!
I finally replaced my cab mounts. I got the kit from ClassicParts.com that included the hardware for my c/20. After reading through threads on the board here, I was expecting the front cab mount bolts to be spot welded to the body, but they were not. All of the bolts loosened very easily thankfully :-)
I don't think I got the wrong kit, but the only piece of the hardware portion of the kit that I used were two washers. I guess I could have used the two new rear bolts, but for the life of me I could not get the new ones to thread, so I used the old bolts with the pointed head, which threaded very easily back into their home. I will post pics of before and after. The four cab mounts took me about 45 minutes to replace. I still need to complete the radiator core mounts. |
1972 C/20
Re: New Cab Mounts!!
Old, notice that one of the tall rear bushings is completely missing.
![]() ![]() New ![]() ![]() |
![]() Join Date: Jul 2000
Very nice!
Is your side trim now misaligned? ![]() I did mine 15 years ago using poly bushings, and they still look like new.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 09-26-2010 at 12:53 PM. |
1972 C/20
The trim is now aligned a little better, which is nice. I went with rubber because every poly bushing that I have ever used squeaks like a mother. It rides so much nicer now too, almost like a sports car lol.
![]() Join Date: Feb 2004
Nice Pics of the mounts, gonna have to right click and save adding them to my tech files
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
EDIT: Answered my own question..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 09-30-2010 at 04:51 PM. |
How did you get the front mounts out?
Were you able to slide the bolt up? I tried to do mine this weekend and there is no way I can lift the cab up to clear the bolt to install the fronts. I got the back done without any issues. |
Grandpa in the rustmobile...
Can anyone vouch for a 'ride/handling' difference between rubber/poly?
Theres some new rubber ones on the board for sale too btw
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#9 | |
I used 3 jacks and some blocks of wood and did one side at a time, one jack by the rear mount, one by the front and another up by the radiator, i raised each jack in about 1" incriments as nessasary to get each mount out and replace them then slowly lowered it back into place. Oh, I did mine with the front clip installed.. It wouldn't hurt to do a little wire brushing a Por-15 around the mount area while your at it..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 02-07-2011 at 08:21 PM. |
There is more than one type of mount depending the truck so do your research.
Poly is a little harder so they can develop a bit of a squeek and they may ride a little harder, but they will last longer. Rubber being softer gives a bit more in the bumps and does not develop the squeak.. Now how long they last? if the rubber makes it 30 years then thats what i'm gonna use..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
do you feel a difference in your ride after the new mounts??
1970 Chevy K20 Custom Camper 1996 Chevy Impala SS 2008 Chevy Avalanche LT3 2003 Honda Accord EX 2001 Hewes Redfisher 16 Fighting Lady Yellow Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118 |
Unfortunantly i havent been driving my truck as its still a bit in pieces...
![]() But think about it, old collapsed and split mounts Vs New taller mounts, i'd say maybe a little, but most of the ride is in the suspension.
#13 |
what a great difference im sure.I know my body mounts are just like your old ones lol.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
#14 |
1972 C/20
Don't know if it's just in my mind, but it seems to feel a little more stable.
#15 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I have had two trucks come into my shop that used urithane mounts and one of the bolts had pulled through the floor when driving up to Capitol Forest. The chassis are designed to be flexible and the bodies are not. Rubber mounts were used so the bodies wouldn't flex with the chassis. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
