need help with my 454
I am putting my 454 together and i have run into a problem, when I bring number one piston to tdc my timing mark on the balancer is pointing at the 5 o'clock position. has the outer ring on my balancer moved, do I have the wrong balancer ( is that possible), am I doing something wrong. Thanks for the help.
1967 swb 454 cid 700R4 trans SOLD 2006 Chevy Trailblazer SS 2013 Camaro RS convertible the wife's Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248 |
Re: need help with my 454
could be either of those ...... old balancers will slip if the rubber ring between the halves is wore out...
did you change your timing pointer maybe to a chrome or aftermarket one?- just reread your post.... I think you got the wrong balancer...
So there is more than one type of balancer for the 454?
Shouldnt be... did you get it in a kit? Can you post a pic?
![]() Join Date: May 2007
If the balancer is used, then I would say the outer ring has walked. I have run into this more than once myself.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
