Old 09-26-2010, 04:20 PM   #1
rfmaster
rfmaster's Avatar
Can not bleed brakes (one side).
As the title says I can not bleed front passenger side on my 75 C20. Over the last couple of months I've noticed that truck pulls to the left when brakes are applied. Since I drive my truck sparingly (on weekends) I thought that my caliper seals is gone and caliper is leaking. Got some re-mfg calipers from Napa and new pads for both sides (kept brake hoses since it looks like it is a PITA to R&R without a lift) for this straight forward refresh brake job. Surprisingly, both caliper seals were dry. Swapping calipers was a simple 10 minute job, but bleeding brakes turned into an 2 hour adventure. I started with passenger side - could not get a drop of fluid with my vacuum MitiVac. Driver side bleeds without a hitch - fluid was draining as it should be. I tried priming right side caliper with brake fluid - MitiVac promptly sucked it dry. Disconnecting brake hose at caliper and applying brakes couple of times resulted in no brake fluid - Master cylinder was full!
I feel a bit dumb founded - what I am missing??? Do I have cracked right side brake line? Caliper hoses appear in good shape and dry (it there a trick way to R&R hoses?)
Need some advise here - please. (The job will have to wait until next weekend - it is 96+ here!)
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 09-26-2010, 04:51 PM   #2
LONGHAIR
Re: Can not bleed brakes (one side).
It is most likely the rubber line. They can collapse internally, which blocks the fliud flow and you can't tell it from the outside.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-26-2010, 05:28 PM   #3
swampfox
swampfox's Avatar
I had the same problem on a 86 1 ton and it was the rubber brake line.
swampfox is offline   Reply With Quote
Old 09-26-2010, 05:48 PM   #4
dman1982
dman1982's Avatar
the other day on my truck the bleeder was full of crap and i had to clean it out.
dman1982 is offline   Reply With Quote
Old 09-26-2010, 09:04 PM   #5
joe231
joe231's Avatar
bad hose
CHEVY ONLY
Old 09-26-2010, 09:42 PM   #6
rfmaster
rfmaster's Avatar
Originally Posted by joe231 View Post
bad hose
Gentlemen - thank you kindly. It looks like I have to R&R caliper hoses (which I purchased ahead of time) in my near future. Now - FSM shows that there is in frame (inside the u-channel) retaining nut and hard line screws into caliper hose. Reaching in there is a bit cramp and (probably) full of dirt and grime. I guess there is no easy way getting there - Crows foot may make it easier????
//RF
"The Beast"
Old 09-28-2010, 12:25 AM   #7
lilpoindexter
lilpoindexter's Avatar
I used a crow foot to try to remove my hard lines at the frame...I also doused them with PB blaster...they came off, but they looked beat, and the nut was rounded a little, so i changed them anyway. I put russel braided flex lines on mine, and i wasnt getting as much fluid from the pass side, as the driver side, so i took the bleeder out, and fluid shot out...I guess the bleeder might have some crap in it, but they bled ok.
By the way, I used the russel speed bleeders, and they kicked ass.
lilpoindexter is offline   Reply With Quote
