Old 09-26-2010, 05:36 PM   #1
djinva
djinva's Avatar
starter flex plate problem?
My truck 71 small block 200r4 has had problems starting since I bought it. It sounds terrible like the starter and flex plate to not match up correctly. I tried to shim the starter but it did not help. The starter looks new, the teeth on the flex plate look pretty good, there is some wear on some of the teeth but nothing major. It has 168 teeth on the flex plate and 9 teeth on the starter. Do I have the wrong starter?
djinva is offline   Reply With Quote
Old 09-26-2010, 06:03 PM   #2
gkesseru
gkesseru's Avatar
Re: starter flex plate problem?
You might have the flexplate backwards. Also, the bolts need to be the right ones. They must fit the starter holes exactly.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 09-26-2010, 06:16 PM   #3
djinva
djinva's Avatar
the flex plate is not backwards and it does have the correct starter bolts.
Old 09-26-2010, 06:39 PM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I beleive there are 2 flex plates 132 tooth and 128 ...don't ask me anymore about which is which...just something I heard when I was fighting starter issues
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-26-2010, 06:39 PM   #5
Tim Christian
Tim Christian's Avatar
I had the same problem on a truck tried three diffrent high torque mini-starters did not work. Put a GM starter on it no problems at all works great!!!!
Tim Christian is offline   Reply With Quote
Old 09-26-2010, 08:20 PM   #6
Putter
More Cowbell....
Putter's Avatar
Tim, that is EXACTLY what my problem is. I pulled a GM "big & heavy" starter off and installed a high-torque mini....just because they sound very cool.
If the motor takes more than about 3 turn-overs to start, it sounds like it slips off the teeth and grinds like crazy!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
